[ GiDlist ] problems with postprocessing .flavia.res
I implemented an output useful for GiD from my FE code. Post process files
are in the new format, and you find them in the attachments.
But GiD finds this error in my result file .flavia.res:
Found EOF too early: in this line: 108 - Reading Results.
[this message appears in a info window]
Line 108 is the last line of the file .flavia.res
Therefore, I cannot post my results clearly; I see also a long list when I
select View Results - Contour Fill, but this is not what I want.
I use GiD 6.1.2.
Can anyone help me?
Thank you in advance
Aldo Ghisi
ALDO GHISI
Politecnico di Milano
Tel.: +39 02 2399 4218
Fax.: +39 02 2399 4220
GiD Post Results File 1.0
GaussPoints “Tria3_1_GP” ElemType Triangle “Tria3_1_GP”
Number of Gauss Points: 1
Natural Coordinates: Internal
End GaussPoints
GaussPoints “Quad4_4_GP” ElemType Quadrilateral “Quad4_4_GP”
Number of Gauss Points: 4
End GaussPoints
Result “Displacements” “es03b” 1 Vector OnNodes
ResultRangesTable “ResultTable”
ComponentNames “X-DISPL”, “Y-DISPL”, “Z-DISPL”
Values
1 0.00000E+00 0.00000E+00
2 -6.86845E-04 -5.53398E-04
3 3.92894E-06 1.78447E-05
4 -6.78444E-04 2.13458E-05
5 0.00000E+00 0.00000E+00
6 -1.75166E-03 -9.27109E-04
7 -8.52555E-04 6.17414E-04
8 -1.73433E-03 2.70467E-05
9 -1.75616E-03 1.02228E-03
10 -2.85734E-03 -9.86065E-04
11 -2.90828E-03 2.83479E-05
12 -3.12001E-03 1.16769E-03
End Values
Result “Reactions” “es03b” 1 Vector OnNodes
ComponentNames “X-REAC”, “Y-REAC”, “Z-REAC”
Values
1 6.86845E-04 5.53398E-04
2 -3.92894E-06 -1.78447E-05
3 6.78444E-04 -2.13458E-05
4 1.75166E-03 9.27109E-04
5 8.52555E-04 -6.17414E-04
6 1.73433E-03 -2.70467E-05
7 1.75616E-03 -1.02228E-03
8 2.85734E-03 9.86065E-04
9 2.90828E-03 -2.83479E-05
10 3.12001E-03 -1.16769E-03
11 0.00000E+00 0.00000E+00
12 0.00000E+00 0.00000E+00
End Values
Result “Stress” “es03b” 1 Matrix OnNodes
ComponentNames “XX-STR”, “YY-STR”, “ZZ-STR” “XY-STR”
Values
1 -1.8839E+00 -4.4562E+00 -1.9020E+00 -1.5438E+00
2 -7.5555E-01 -2.4206E+00 -8.1245E-01 -1.1560E+00
3 -6.0784E-01 -1.4614E+00 -6.2076E-01 -1.1360E+00
4 -1.6667E-01 7.1489E-01 1.9710E-01 -1.0694E+00
5 3.5565E-01 2.1994E+00 7.6651E-01 -1.1039E+00
6 -3.3196E-01 -1.9817E+00 -4.8138E-01 -9.2480E-01
7 -7.6968E-02 3.3601E+00 8.6123E-01 -7.9987E-01
8 -3.5712E-01 -2.0002E-01 -1.3230E-01 -8.4685E-01
9 -9.0847E-01 1.5384E+00 9.8198E-02 -8.0979E-01
10 -4.4375E-01 -5.7841E-01 -2.5554E-01 -8.7097E-01
11 -1.3169E+00 2.9780E-01 -2.5478E-01 -1.0505E+00
12 -2.7428E+00 1.2572E+00 -3.7138E-01 -1.2572E+00
End Values
Result “Strains” “es03b” 1 Matrix OnNodes
ComponentNames “XX-EPS”, “YY-EPS”, “ZZ-EPS” “XY-EPS”
Values
1 7.8579E-07 -1.1068E-04 0.0000E+00 -1.3380E-04
2 2.0284E-06 -5.6583E-05 0.0000E+00 -6.0575E-05
3 5.6010E-07 -3.6426E-05 0.0000E+00 -9.8456E-05
4 -7.5831E-06 1.0640E-05 0.0000E+00 -5.0567E-05
5 -1.7804E-05 6.2092E-05 0.0000E+00 -9.5670E-05
6 3.2399E-06 -3.9940E-05 0.0000E+00 -3.4796E-05
7 -2.0411E-05 6.0200E-05 0.0000E+00 -3.4058E-05
8 -3.7766E-06 -1.2052E-05 0.0000E+00 -3.1415E-05
9 -1.7976E-05 1.6103E-05 0.0000E+00 -3.2713E-05
10 -3.3609E-06 -5.7655E-06 0.0000E+00 -3.1106E-05
11 -1.8967E-05 9.8676E-06 0.0000E+00 -3.7518E-05
12 -4.2346E-05 2.9082E-05 0.0000E+00 -4.4901E-05
End Values
Result “Stress” “es03b” 1 Matrix OnGaussPoints
Values
1 -1.961E-02 1.468E-02 -1.481E-03 -1.616E+00
2 -1.884E+00 -4.456E+00 -1.902E+00 -1.544E+00
3 7.998E-02 5.736E-02 4.120E-02 -2.484E-01
4 7.309E-01 4.384E+00 1.535E+00 -5.919E-01
5 -3.847E-01 -2.013E+00 -4.795E-01 -1.496E+00
6 -8.004E-01 1.938E+00 2.276E-01 -1.044E+00
7 -3.898E-02 -8.934E-01 -2.331E-01 -8.485E-01
8 -8.485E-01 -2.634E-01 -2.780E-01 -8.934E-01
9 -3.595E-01 -1.004E-01 -1.150E-01 -1.001E+00
10 -2.743E+00 1.257E+00 -3.714E-01 -1.257E+00
End Values
Result “Strains” “es03b” 1 Matrix OnGaussPoints
Values
1 -7.858E-07 7.002E-07 0.000E+00 -1.400E-04
2 7.858E-07 -1.107E-04 0.000E+00 -1.338E-04
3 1.680E-06 7.002E-07 0.000E+00 -2.153E-05
4 -3.482E-05 1.235E-04 0.000E+00 -5.130E-05
5 2.276E-06 -3.680E-05 0.000E+00 -7.183E-05
6 -2.467E-05 4.106E-05 0.000E+00 -5.013E-05
7 3.466E-06 -1.179E-05 0.000E+00 -3.030E-05
8 -1.019E-05 2.602E-07 0.000E+00 -3.191E-05
9 -4.367E-06 2.602E-07 0.000E+00 -3.574E-05
10 -4.235E-05 2.908E-05 0.000E+00 -4.490E-05
End Values
FEAP Es03b
numnp,numel,nummat,ndm,ndf,nen,nen1
12 10 3 2 2 4 9
Mesh “Only_coordinates” Dimension 2 ElemType Triangle Nnode 3
Coordinates
1 0.0000 0.0000
2 0.0000 5.0000
3 5.0000 0.0000
4 5.0000 5.0000
5 10.0000 0.0000
6 0.0000 10.0000
7 10.0000 5.0000
8 5.0000 10.0000
9 10.0000 10.0000
10 0.0000 15.0000
11 5.0000 15.0000
12 10.0000 15.0000
End coordinates
Elements
no elements entered, they will be in the successive meshes
End elements
Mesh “Tria3_1_GP” Dimension 2 ElemType Triangle Nnode 3
Coordinates
no coordinates entered, they are already in the first mesh
End coordinates
Elements
1 3 5 4 1
2 2 1 3 1
3 3 4 2 1
4 7 4 5 1
7 6 8 10 3
8 8 11 10 3
9 8 9 11 3
10 9 12 11 3
End elements
Mesh “Quad4_4_GP” Dimension 2 ElemType Quadrilateral Nnode 4
Coordinates
End coordinates
Elements
5 2 4 8 6 2
6 4 7 9 8 2
End elements
Hi Aldo Gishi,
the new postprocess results format needs GiD version 6.1.4b or higher
( ftp://gid.cimne.upc.es/pub/gid_adds/Windows).
After taking a look into your es03b.flavia.res file, several points
must be clarified ( http://gid.cimne.upc.es/support/gid_16.html#SEC226):
· Result names should unique within the same step.
In your file results “Stress” and “Strains” are defined twice: once on nodes,
and again for Gauss Points.
· If a result is defined OnGaussPoints, the Gauss Points name, where the result
is defined, should be given.
In your file the second results “Strains” and “Stress” are defined over Gauss Points
without telling GiD which GaussPoints should be used: “Tria3_1_GP” or “Quad4_4_GP”.
· The ‘ResultRangesTable’ and ‘ComponentNames’ are optional, but:
  • If a ‘ResultRangesTable’ is specified inside a Result, this ‘ResultRangesTable’
    must be defined before.
    In your file, results should use the ResultRangesTable “ResultTable” but
    this table is not defined anywhere.
  • ‘ComponentsNames’ should be separated with commas, but in your file, some of
    them are only separated by spaces. Although it may work now, it is not guaranteed
    that later works.
enclosed, i send you a corrected version of your ‘es03b.flavia.res’ file
hope it helps,
I use GiD 6.1.2.
Can anyone help me?
Aldo Ghisi
ALDO GHISI
End GaussPoints
End GaussPoints
Values
End Values
Values
End Values
Values
End Values
Values
End Values
Result “Stress 2” “es03b” 1 Matrix OnGaussPoints “Tria3_1_GP”
Values
End Values
Result “Strains 2” “es03b” 1 Matrix OnGaussPoints “Tria3_1_GP”
Values
End Values
