[GiDlist] Problems with lable select res
Hi everyone,
I’m using GiD 7.4.9 b in Windows for post processing files of 3D elasticity and the
command:
label Select resultonview (using the mouse)
seems not to work. My result is a gauss points one.
To have a quick look at the result values I have to zoom so that the displayed part
contains only few elements and than use
label resultonview
I had the same problem with previous versions of GiD but it seemed to be rotation
dependent: the command worked if the labels were mostly outside the model surface.
With this version the command never works.
I append a zip file with an example called “Slab_4.gid”.
Thanks for any help.
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
Hi, i did not receive the file. Perhaps is because of the double extension that
the antivirus mail parses deletes it.
Pleas try with something like slab_4_gid.rar
thanks
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Andrea Calaon
Enviado el: viernes, 13 de agosto de 2004 11:51
Asunto: [GiDlist] Problems with lable select res
Hi everyone,
the
command:
part contains only few elements and than use
label resultonview
rotation
surface.
Andrea Calaon
SO40 7AA, UK
I do not understand very well the problem. I displayed, for instance, a controu
fill of Stress#T and then i’ve done ‘label-select-results’ and then selected
some gauss points and then it displayed its results values: LabelGPResults.gif
But if the problem lies in the size of the font used to display de labels, in
the ‘Utilities-preferences’ window there is a ‘font’ panel, from where you can
select the type and size of the font used to draw the labels, under the text
‘Label/Dimensions Font’.
Hope it helps,
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Miguel A. Pasenau de
Riera
Enviado el: viernes, 13 de agosto de 2004 12:48
Asunto: RE: [GiDlist] Problems with lable select res
thanks
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Andrea Calaon Enviado
Hi everyone,
the
command:
label resultonview
rotation
surface.
Andrea Calaon
SO40 7AA, UK
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040813/410a68df/attachment.gif
Dear Miguel,
I try now following working configuration.
Client: Windows XP
-GiD 7.4 (pre- and post)
Server: Redhat Linux
-Fortran90 (solver)
In GiD, I notice, we can use “calculate remote”. I try using all the
required information, but it doesn’t work.
My questions:
  1. What kind of connection do you use? must I chage some settings on the
    server-side?
  2. Where must I put the name (incl. path) of the program on the linux
    machine? The data required is only: Remote server, Group, User and Password.
    How do you know where the FEM-program is?
Another question is, if I “mount” or map a network directory in Windows XP,
can I open in GiD the mapped files, so that I can let model- and
result-files on the server? If yes, please inform me, then I will start to
install Samba on linux for this purpose.
Thanks a lot for your help!!
Rafael
The ‘calculate remote’ option require another CIMNE’s program, installed on
the server machine: ProcServer (and the problemtype off course)
GiD directly comunicates (using TCP/IP) with ProcServer to send and retrieve
the calculation information.
Note: At this moment procserver is not available for public download.
I think that GiD can access without problems to a mapped network directory
in Windows XP,
Sent: Wednesday, August 18, 2004 4:52 AM
Subject: [GiDlist] Calculate Remote
Dear Miguel,
Client: Windows XP
-Fortran90 (solver)
My questions:
server-side?
Password.
XP,
Rafael
