Dear Enrique,
Enclosed you can find some files defining my problem
and the associated flavia.res file.
For some reasons I get the following error when selecting postprocess:
couldn’t find ‘end values’, in line 1361 of file
‘e:\GID\Straw_FE_meshes\straw02.gid\straw02.flavia.res’.
Is there a limitation to the number of nodes to which you can assign scalar
result values?
Or do I have another problem.
PS: I followed the instructions from the user manual and the postprocess
tutorial.
Many thanks in advance for helping me !!!
Greetings
Nico
Nico Scheerlinck
Laboratory of Postharvest Technology
W. De Croylaan 42
B-3001 Leuven
Tel: +32 (0)16 32 26 68
Fax: +32 (0)16 32 29 55
Email: nico.scheerlinck at agr.kuleuven.ac.be
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020725/55e48822/attachment.bin
The problems are:
1- the node number is an integer, not a float.
example: instead
1.356e+003 4.4777794e+001
use:
1356 4.4777794e+001
2- After the last word “End Values” enter a carriage return
I’ attach the file corrected.
GiD is limited only in the academic unregistered version (máx 3000 volume elements or 700 surface elements)
From: “Nico Scheerlinck” nico.scheerlinck at agr.kuleuven.ac.be
To: GiDlist at gatxan.cimne.upc.es
Sent: Thursday, July 25, 2002 7:13 PM
Subject: [GiDlist] Problems with entering res file
Dear Enrique,
result values?
tutorial.
Greetings
Nico
Nico Scheerlinck
W. De Croylaan 42
B-3001 Leuven
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020725/be5d7861/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020725/be5d7861/attachment.obj
