[GiDlist] Problem writing EPS file (Alejandro A. Ortiz Berna
Hello Alejandro A. Ortiz Bernardin,
I come up with exactly the same problem yesterday for writing a PNG file.
The same message appeared as you mentioned. But immediately i came to know
that the problem was some bad / unacceptable character in the file name.
When i renamed the filename with common characters, the problem was
resolved and PNG was successfully written. May be you can also try this.
Good Luck.
Ismat
On Tue, Aug 28, 2012 at 3:00 PM, gidlist-request at listas.cimne.upc.eduwrote:
Today’s Topics:
1. Problem writing EPS file (Alejandro A. Ortiz Bernardin)
Message: 1
Date: Mon, 27 Aug 2012 18:42:43 -0400
From: “Alejandro A. Ortiz Bernardin” aortizb at gmail.com
Subject: [GiDlist] Problem writing EPS file
Message-ID: 016301cd84a5$47461d20$d5d25760$@com
Content-Type: text/plain; charset=“iso-8859-1”
I am trying to write an EPS file in GiD v11, but I found the following
problem when printing it:
“Couldn?t write ps/eps file. Test permissions and quotas.”
What does it mean and how can I resolve this issue?
Alejandro.
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120827/90c8e715/attachment.html_
End of GiDlist Digest, Vol 25, Issue 6
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120829/7a7a3622/attachment.htm
maybe the problem is as Alejandro pointed a problem to open a file withno
To: gidlist at listas.cimne.upc.edu ; aortizb at gmail.com
Sent: Wednesday, August 29, 2012 5:30 AM
Subject: Re: [GiDlist] Problem writing EPS file (Alejandro A. OrtizBernardin)
I come up with exactly the same problem yesterday for writing a PNG file. The same message appeared as you mentioned. But immediately i came to know that the problem was some bad / unacceptable character in the file name. When i renamed the filename with common characters, the problem was resolved and PNG was successfully written. May be you can also try this.
Good Luck.
Ismat
On Tue, Aug 28, 2012 at 3:00 PM, gidlist-request at listas.cimne.upc.edu wrote:
Today’s Topics:
Message: 1
Alejandro.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120827/90c8e715/attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120829/a3e50fb0/attachment.htm
Maybe the problem is as Ismat pointed a problem to open a file with non ASCII characters.
Which platform are you using? Linux or Windows? and what is the exact GiD version (see help-about)?
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120829/a6ab8802/attachment-0001.htm
Thanks for the reply. However is not the case mentioned by Ismat. Attached
are two figures that show the problem. I am using GiD 10.0.9 win64.
Alejandro.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Enrique Escolano
Enviado el: Wednesday, August 29, 2012 2:45 PM
Asunto: Re: [GiDlist] Problem writing EPS file (Alejandro A. OrtizBernardin)
ASCII characters.
From: Ismat Ismatullah mailto:ismatullah at gmail.com
OrtizBernardin)
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL:
attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120830/1b2bddac/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120830/1b2bddac/attachment-0002.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120830/1b2bddac/attachment-0003.png
The full path must be ASCII to avoid problems opening the file, not only the file name and last folder name.
It is your case? (try saving inside a path without non-ASCII characters, like C:\tmp\my_file.eps)
On the other hand your problem could be another…
Sent: Thursday, August 30, 2012 6:36 AM
Thanks for the reply. However is not the case mentioned by Ismat. Attached are two figures that show the problem. I am using GiD 10.0.9 win64.
Alejandro.
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Enrique Escolano
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120830/dd3fb444/attachment.htm
It is not my case. The path and name is fully ASCII. However, the default
path to GiD folder has spaces in it.
Enviado el: Thursday, August 30, 2012 10:40 AM
From: Alejandro A. Ortiz Bernardin mailto:aortizb at gmail.com
OrtizBernardin)
Alejandro.
ASCII characters.
OrtizBernardin)
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL:
attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120831/cdbadd38/attachment.htm
I just bought the license for GiD v11 and the same problem persists. It
gives me the same error: “Couldn’t write ps/eps file. Test permissions and
quotas.”
De: Alejandro A. Ortiz Bernardin [mailto:aortizb at gmail.com]
Enviado el: Friday, August 31, 2012 2:20 PM
Para: ‘gidlist at listas.cimne.upc.edu’
Asunto: RE: [GiDlist] Problem writing EPS file (Alejandro A. OrtizBernardin)
OrtizBernardin)
Alejandro.
ASCII characters.
OrtizBernardin)
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL:
attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120831/1934a2aa/attachment-0001.htm
I just tried in another machine that uses Ubuntu. It also fails for both
versions 10 and 11.
Enviado el: Friday, August 31, 2012 3:30 PM
quotas.”
OrtizBernardin)
Alejandro.
ASCII characters.
OrtizBernardin)
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL:
attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120831/a58f26d5/attachment.htm
Here is another thing I tried.
For GiD v10.0.9 one machine running Windows and another machine running
Ubuntu:
I tried to obtain an EPS file with resolution 600. In both cases I got the
error that is depicted in the attached figure.
For GiD v11.1.0 and GiD v11.1.0d one machine running Windows and another
machine running Ubuntu:
I tried to obtain an EPS file with resolution 600. In both cases I got only
the warning: “Couldn´t write ps/eps file. Test permissions and quotas”.
Enviado el: Friday, August 31, 2012 5:26 PM
versions 10 and 11.
quotas.”
OrtizBernardin)
Alejandro.
ASCII characters.
OrtizBernardin)
Good Luck.
Ismat
Today’s Topics:
Message: 1
Alejandro.
URL:
attachment.html
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120831/409529d5/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120831/409529d5/attachment-0001.png
