If your poit size is too small, try if exists some setting of your
graphic card to correct it.
Note: Find this setting in Windows (not in GiD):
screen properties - configuration - advanced…
Try also to update your graphic card driver.
Sent: Thursday, February 13, 2003 10:20 AM
Subject: Re: [GiDlist] Problem with selecting points
Many thanks!
Compared with the point size in other user’s GID, the point size in my GID
is
much smaller, and I can’t see it clearly, so I can’t work on.
Something must be wrong with my GID setting.
Chen
Enrique Escolano wrote:
Until this future beta version, the point size cannot be changed.
Sent: Wednesday, February 12, 2003 7:39 PM
Many thanks!
I know where to change the color of point, line, etc., but I don’t
know
where to
change point size.
If you could tell me it will be much appreciated!
Chen
For the next beta version, we are working in a “custom render” mode.
The user can create more “user-defined” render modes, setting some
options:
point and line size, color by layer or by entity type, etc.
Sent: Wednesday, February 12, 2003 6:10 PM
Many thanks, but this problem still exists for both GID6.3.0b and
GID7.2.
When I want to create a line, I just wish its two boundary points
to
be
bigger.
Chen
Javier Mora wrote:
Other suggestion: check a newer version, GiD7.2 or the last beta
version
of
GiD6:
ftp://gid.cimne.upc.es/pub/gid_adds/Windows/Old/GiD6.3.0b-win.exe
(12.6
MB)
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Chen
Guangjing
Enviado el: miércoles, 12 de febrero de 2003 16:03
Asunto: Re: [GiDlist] Problem with selecting points
Hi, Javier
Many thanks for your reply!
But for me I hope the points selected to be marked by bigger
red point.
This problem happened recently, and there was no such problem
with
my
previous GID.
Chen
Javier Mora wrote:
You can use two additional tools:
Utilities - Signal - Points (the point is signed using four
lines)
View - Label - All in - Points (you will see a label for
each selected
point)
Chen Guangjing
Enviado el: miércoles, 12 de febrero de 2003 15:21
Para: GiDlist at gatxan.cimne.upc.es
Asunto: [GiDlist] Problem with selecting points
Dear Sir/Madam
There is a problem with my GID 6.1.2:
when I select a point from a geometric figure or mesh, the
point becomes
red, but the red point is so small that it is difficult
to see the red
color clearly.
so could you please do me a favor to tell me how to
improve
it?
I look forward to your reply!
Yours sincerely,
Chen Gaungjing
Edificio D2
