The problem type problem_type_solid2 from the GiD distribution is only a
sample of configuration files.
The analysis program (called from problem_type_solid2.bat ) is not included.
If you search a finite element program to solve structural problems of
beams, shells and 3D solids, look at this web page:
http://gid.cimne.upc.es/ram-series
This program works on Windows or Linux, and GiD version 6 or more is also
required.
Sent: Monday, March 31, 2001 11:48 AM
Subject: [ GiDlist ] problem_type_solid2.bat doesn’t exist and postprocessor
doesn’work
I have downloaded and installed GID 6.1.2.a , but
problem_type_solid2.bat doesn’t exist in tar file.
-Somebody con send me this file?
So to try program I have copied problem_type_solid2.bat
from release 5 , and postrprocessor works (but I don’t know
if results are good) only with examples (es. arc3d.gid).
-Wich is the problem when postprocessor don’t show any
results?
I have verified that files …flavia.res, flavia.mesh
aren’t written.
-The problem is in point loads or in point constrants?
To be sure I have resolved the same flex problem with Stan
lee finite elements (postprocessor) and it show a solution
without problems.
Thank you
Antonio Riccucci
Italy
