[ GiDlist ] problem_type_solid2.bat doesn't exist and po
I have downloaded and installed GID 6.1.2.a , but
problem_type_solid2.bat doesn’t exist in tar file.
-Somebody con send me this file?
So to try program I have copied problem_type_solid2.bat
from release 5 , and postrprocessor works (but I don’t know
if results are good) only with examples (es. arc3d.gid).
-Wich is the problem when postprocessor don’t show any
results?
I have verified that files …flavia.res, flavia.mesh
aren’t written.
-The problem is in point loads or in point constrants?
To be sure I have resolved the same flex problem with Stan
lee finite elements (postprocessor) and it show a solution
without problems.
Thank you
Antonio Riccucci
Italy
