[GiDlist] Priority of 'Force mesh' vs 'mesh/no m
The problem is in the case where there an inconsistency between the
preferences variable to force mesh some kind of entity (e.g. surfaces like
your example) and the information set to some entities to not to mesh some
surfaces.
In last 11.1.9d version the preference variable has priority over the other
information assigned to entities, and in previous versions seems the
priority in case of contradiction was the opposite.
Really I think that is more logical the old priority, and the used-assigned
data (to not to mesh some surfaces), must override the value of the global
variable to force mesh all surfaces.
Probably this change has been unwanted and it is more a secondary effect of
other changes, and we must to restore the old behavior for next GiD versions
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mark Smith
Enviado el: martes, 24 de junio de 2014 11:51
Asunto: Re: [GiDlist] STEP file import
Hi Enrique,
Thank you.
It may not be a bug but the “mesh criteria - no-mesh - volumes” over rides
this setting on earlier versions of GiD including 11.0.6 which seems more
sensible?
Mark
On Mon, 6/23/14, Enrique Escolano escolano at cimne.upc.edu wrote:
Subject: Re: [GiDlist] STEP file import
Date: Monday, June 23, 2014, 4:05 PM
It seems that is not a
bug of the 11.1.9d version,
As I have
pointed, in your model do you have set the preference Meshing-Other -
Mesh always by default. For surfaces= true Uncheck it and generate the
mesh again.
En nombre de Enrique Escolano
Enviado el:
lunes, 23 de junio de 2014 13:09
Please, send us a zip with the
model to check it.
(can send directly to my
e-mail instead of the gidlist)
De:
Enviado el: lunes,
23 de junio de 2014 12:36
Para: GiDlist
Hi Gid team,
When opening saved gid model (from 11.1.9d|) in ver 11.0.6 mesh/no mesh
assignments are respected, so it must be a bug in 11.1.9d ?
Mark
On Mon, 6/23/14, Mark Smith piedycat at yahoo.com
wrote:
Subject: Re:
Date: Monday, June 23, 2014, 11:16 AM
Hi GiD team,
I have downloaded ver 11.1.9d, and the STEP import works but reports
errors although it seems to have imported it OK.
I have a
problem when
meshing as the mesher
doesen’t obey the mesh/no-mesh criteria I have imposed on lines,surfaces
and volumes although when you do mesh-draw-mesh/no mesh it shows those
entities which should & shluld not be meshed but the mesher ignores the
asignments:?
Mark
On Fri, 6/20/14, Enrique Escolano escolano at cimne.upc.edu
STEP file import
Date: Friday, June 20, 2014, 2:22 PM
In fact the STEP
import
is implemented in the last
11.1.9d, you can download
and use it
now,
but some
things have been fixed and
enhanced for the version 12
(available
the 17 July during the 7th GiD
convention)
Users upgrading
from version 11 to 12 will
have a 60 % of discount of
version 12
prices (these prices are not
available
until version 12
will be
available)
STEP export is not
implemented for version
12.0.x
official,
but probably it
will appear
in some
12.1.xd developer versions (during the next two
years
until a new
official version will be
released)
-----Mensaje
original-----
De:
Enviado el: viernes,
20 de
junio de 2014
14:36
Hi
Abel,
Will it be able
to export STEP as
well?
Mark
On Thu, 6/19/14, Abel Coll abelcs at cimne.upc.edu
wrote:
Subject: Re:
Date: Thursday, June 19, 2014, 7:18 PM
Dear Mark,
We
have
just implemented this
capability within
the last months. It
will
be available in
the new 12th
version,
which will be released during the GiD Conventoin (July
17th and
18th).
Kind
regards,
ABEL
Abel
Coll
Sans - Civil
Engineer
CIMNE - International
Center for Numerical Methods in
Engineering Ofice
c-2,
C1 building -
Campus Nord UPC Gran
Capità s/n,
08034
Barcelona
T: 34 -
93
401 74 03 Fax:
34
93 40 65 17
-----Mensaje
original-----
De:
Enviado el: jueves,
19 de
junio de 2014
18:15
Para: GiDlist
Asunto:
Are there any plans to allow
GiD to import STEP
files?
mark
