[GiDlist] Preproces - Import File
Hello all,
I have a file containing information of a mesh (i.e. coordinates and elements info).
Is it possible to create a GiD project only with this data and open it as a project in the preprocess ?
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040211/eb6f2499/attachment.htm
Copy this GiD mesh, for example named “test.msh”, inside a directory named “test.gid”.
It’s needed also a .geo file, copy a “test.geo” file, renamed from another GiD model.
After load, can delete the undesired geometric entities of this model.
Sent: Wednesday, February 11, 2004 9:21 PM
Subject: [GiDlist] Preproces - Import File
Hello all,
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/3b4d7636/attachment.htm
Hello Enrique,
There are no example files attached to your message.
Can you pkease re-send your message with the attached files ?
Dganit
Sent: Thursday, February 12, 2004 11:41 AM
Subject: Re: [GiDlist] Preproces - Import File
Hello all,
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040213/154c7ad0/attachment.htm
Not, I did non attach any file.
I speak about your *.mesh file, and a generic *.geo (open GiD, save the model, and use this geo)
Sent: Friday, February 13, 2004 12:57 PM
Hello Enrique,
Dganit
Hello all,
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040213/da29c2cb/attachment.htm
To import a mesh inside GiD, you mush use:
Files-Import-GiD mesh
If you want to make it become automatically a project, you must create a
batch file
that imports the mesh and saves a project.
You can make GiD do this without opening any window by calling GiD with
something like: gid -n … (check the help for details)
http://www.compassis.com http://www.compassis.com/
ramsan at compassis.com
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de dganit
Enviado el: miércoles, 11 de febrero de 2004 21:22
Asunto: [GiDlist] Preproces - Import File
Hello all,
elements info).
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/93931b49/attachment.htm
MensajeNote: Can use Files-Import-GiD mesh
Only if the file is written in GiD mesh ASCII format, but not if the file is binary format.
Sent: Thursday, February 12, 2004 3:02 PM
Subject: RE: [GiDlist] Preproces - Import File
If you want to make it become automatically a project, you must create a batch file
De: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de dganit
Hello all,
Dganit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040212/8dee45eb/attachment.htm
