Note that the old postprocess format requires 15 characters as the
description name. So, in this case the number 1 must begin at column 16.
By the way, if possible, it is better to use the new postprocess format
that have a new and better way to define the headers of the results.
You can check this new format in the GiD help.
De: owner-gid at gatxan.cimne.upc.es [mailto:owner-gid at gatxan.cimne.upc.es]En
nombre de Changho
Enviado el: viernes, 10 de agosto de 2001 20:12
Asunto: [ GiDlist ] PostProcessing on time analysis
Hello all
I met a problem to do postprocessing. I’m doing the earthquake analysis
using time step. And my header of result has
" Displacement 1 0.02 2 1 1"
" Displacement 1 0.04 2 1 1"
" Displacement 1 0.06 2 1 1"
As you see, 0.02,0.04, and 0.06 are the time step in my analysis. But, GID
postprocessor complains when I load this result files. This real time step
number is not allowed in GID?
thanks
Changho Choi
Department of Civil Engineering
Box 352700 More 132A
University of Washington phone: 206-729-3542 (H)
Seattle WA 98195 206-543-6778 (O)
206-543-1543 (fax)
I’m using Gid 6.1.2.
Is it working for new format
Changho Choi
206-543-1543 (fax)
On Fri, 10 Aug 2001, [iso-8859-1] Ramon Ribó wrote:
_Hello,_
_Note that the old postprocess format requires 15 characters as the_
_description name. So, in this case the number 1 must begin at column 16._
_By the way, if possible, it is better to use the new postprocess format_
_that have a new and better way to define the headers of the results._
_You can check this new format in the GiD help._
_Regards,_
_--_
_Compass Ing. y Sistemas Dr. Ramon Ribó_
_http://www.compassis.com [ramsan at compassis.com](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_c/ Manuel Girona, 61 bajos tel. +34 93 204 10 82_
_08034 Barcelona, Spain fax. +34 93 204 19 09_
_-----Mensaje original-----_
_De: [owner-gid at gatxan.cimne.upc.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) [mailto:[owner-gid at gatxan.cimne.upc.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)]En_
_nombre de Changho_
_Enviado el: viernes, 10 de agosto de 2001 20:12_
_Para: [gidlist at gatxan.cimne.upc.es](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_Asunto: [ GiDlist ] PostProcessing on time analysis_
_Hello all_
_I met a problem to do postprocessing. I'm doing the earthquake analysis_
_using time step. And my header of result has_
_" Displacement 1 0.02 2 1 1"_
_....._
_" Displacement 1 0.04 2 1 1"_
_....._
_" Displacement 1 0.06 2 1 1"_
_....._
_As you see, 0.02,0.04, and 0.06 are the time step in my analysis. But, GID_
_postprocessor complains when I load this result files. This real time step_
_number is not allowed in GID?_
_thanks_
_~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_
_~_
_Changho Choi_
_Department of Civil Engineering_
_Box 352700 More 132A_
_University of Washington phone: 206-729-3542 (H)_
_Seattle WA 98195 206-543-6778 (O)_
_206-543-1543 (fax)_
