[GiDlist] Postprocessing - Interpolation
Hello there!
Does GID have the capabalilities to interpolate a set of values associated
with a set of scattered data points to a generated mesh?
In a typical numerical work this might be done by Delauney triangularization
of the scattered data points (2D problem) and then local interpolation
within each triangular to the vertices of the mesh.
Can anyone help with this request??
Alternatively can GID mesh through a set of scattered data points? Seems to
me I need at least lines to mesh.
Many thanks
Tim Kendon
Imperial College
Internally, GiD can create a Delaunay mesh or triangles from a set or points
(2D or 3D projected in 2D), but this capability is not public.
You can use some program as “Surfer” (www.goldensoftware.com) for your
pourposes.
To: “‘gidlist at gid.cimne.upc.es’” gidlist at gatxan.cimne.upc.es
Sent: Thursday, March 14, 2002 10:46 AM
Subject: [GiDlist] Postprocessing - Interpolation
Hello there!
triangularization
to
Many thanks
Tim Kendon
Imperial College
You can use the “triangle” software, is free and with code.
pourposes.
Hello there!
triangularization
to
Many thanks
Tim Kendon
Imperial College
The address of "triangle:Triangle: A Two-Dimensional Quality Mesh Generator and Delaunay Triangulator
pourposes.
Hello there!
triangularization
to
Many thanks
Tim Kendon
Imperial College
