[GiDlist] Postprocess from ABAQUS
Hi everybody
How it is possible to translate the ABAQUS 6.2 *.fil result file in the
*.flavia.res GID postprocess result file?
Thanks for any suggestion.
Best Regards
Franco Di Persio
I’ unknown the ABAQUS 6.2 *.fil result file format.
Probably he is quite simple to write a program that reads and rewrites in
GiD format.
If it has a manual of reference that explains this format, and some sample,
send us, and we study the possibility
or directly importing from GiD.
Sent: Friday, July 19, 2002 12:27 PM
Subject: [GiDlist] Postprocess from ABAQUS
Hi everybody
Best Regards
Franco Di Persio
Hi Miguel,
I tried Gid6.1.3 on the Sun but got the same problem. It was working all right if I did
not assign the conditions. However, after I assigned the conditions and when I was
trying to mesh the geometry, the program automatically shut down and gave an error
message: “segmentation fault”.
Shuo Ma
X-UIDL: X4i"!A^j!!AH`!!$gK"!
Envelope-to: sma at crustal.ucsb.edu
Delivery-date: Fri, 19 Jul 2002 01:27:22 -0700
From: “Miguel A. de Riera Pasenau” miguel at cimne.upc.es
X-Accept-Language: en
MIME-Version: 1.0
To: gidlist at gatxan.cimne.upc.es, Jorge Suit Perez Ronda ronda at cimne.upc.es
Subject: Re: [GiDlist] gid7 for Sun system
Content-Transfer-Encoding: 7bit
X-BeenThere: gidlist at gid.cimne.upc.es
X-Mailman-Version: 2.0.6
List-Help: mailto:gidlist-request at gid.cimne.upc.es?subject=help
List-Post: mailto:gidlist at gid.cimne.upc.es
_List-Subscribe: http://gid.cimne.upc.es/mailman/listinfo/gidlist,_
mailto:gidlist-request at gid.cimne.upc.es?subject=subscribe
List-Id: GiD users mailing list. gidlist.gid.cimne.upc.es
_List-Unsubscribe: http://gid.cimne.upc.es/mailman/listinfo/gidlist,_
mailto:gidlist-request at gid.cimne.upc.es?subject=unsubscribe
_List-Archive: http://gid.cimne.upc.es/pipermail/gidlist/_
X-Original-Date: Fri, 19 Jul 2002 10:25:41 +0200
X-Received-From-Host: dukas.upc.es
hello,
yes we’ve received your email,
we’re working on it trying to find the problem,
we are using a sun from another department.
have you tried to use the version 6.1.3 for Sun?
did you get the same problem?
_ftp://gid.cimne.com/pub/gid/Sun/gid6.1.3.tar.gz_
you can still get a one month password for this version
_http://gid.cimne.com/password/pa01.subst_
Shuo Ma wrote:
Hi Miguel,
Did you receive my e-mails? I was waiting for your answer. I know there must be
problems with Gid on the Sun system. Is it easy to fix?
I’ll use Gid to generate more than 10 million nodes for my 3D finite element
mesh. I was wondering how much memory it needs. I know this certainly cannot be
done on a PC. In our institute there is a 8 GB memory Sun system. But
unfortunately, I met some problems with Gid on the Sun as my previous e-mails
mentioned.
I contacted the coordinator in the San Diego Supercomputer Center and try to use
their computer. But I don’t know whether Gid works on their system.
regards,
Shuo Ma
Recently I installed gid7 on one Silicon Graphics machine. When I ran gid.exe it
gave me the following messege:
crunch 22% uname -a
IRIX64 crunch 6.4 02121744 IP27
crunch 23% ls -l
total 59360
drwxr-xr-x 10 sma ics 4096 Jul 22 15:12 Examples
-rw-r–r-- 1 sma ics 1300 Jun 27 06:00 README.txt
drwxr-xr-x 2 sma ics 20480 Jul 22 15:12 bitmaps
-rwxr-xr-x 1 sma ics 465752 Oct 15 2001 gen2dNNN
-rwxr-xr-x 1 sma ics 353 Jul 22 15:13 gid
-rwxr-xr-x 1 sma ics 14014960 Jun 27 05:01 gid.exe
-rwxr-xr-x 1 sma ics 226 Oct 15 2001 gid.sample
-rw-r–r-- 1 sma ics 15257995 Jul 22 15:11 gid7.0.tar.gz
drwxr-xr-x 8 sma ics 4096 Jul 22 15:12 info
-rwxr-xr-x 1 sma ics 819 Jun 27 05:58 install
drwxr-xr-x 2 sma ics 87 Jul 22 15:12 lib
-rwxr-xr-x 1 sma ics 585393 Oct 15 2001 mesh3d99
drwxr-xr-x 4 sma ics 42 Jul 22 15:12 problemtypes
drwxr-xr-x 3 sma ics 12288 Jul 22 15:12 scripts
drwxr-xr-x 2 sma ics 4096 Jul 22 15:12 symbols
drwxr-xr-x 2 sma ics 78 Jul 22 15:12 templates
crunch 24% gid.exe
18936:gid.exe: rld: Error: unresolvable symbol in gid.exe: __libc_attr
18936:gid.exe: rld: Fatal Error: this executable has unresolvable symbols
crunch 25% gid
27493:/home/crunch/sma/gid7/gid.exe: rld: Error: unresolvable symbol in
/home/crunch/sma/gid7/gid.exe: __libc_attr
27493:/home/crunch/sma/gid7/gid.exe: rld: Fatal Error: this executable has
crunch 26%
I tried the Gid6.1.3 and it’s the same problem.I am sorry I kept asking so many
questions since I desperately want to get Gid work on these systems. Are there
any progress on the Sun? Can you keep me informed?
thanks a lot,
Shuo Ma
Ya,
gid was compiled in a IRIX64 obelix 6.5 10181059 IP27
machine.
we’ll look for an irix 6.4 machine, since all our silicon machines
are using this last sgi release (irix 6.5).
crunch 22% uname -a
crunch 23% ls -l
total 59360
crunch 24% gid.exe
_18936:gid.exe: rld: Error: unresolvable symbol in gid.exe: _libc_attr
crunch 25% gid
_/home/crunch/sma/gid7/gid.exe: _libc_attr
crunch 26%
thanks a lot,
Shuo Ma
Can anyone give an example of how to write a complete batch file? Since I’ll
use Gid to generate millions of nodes the mesh generation process and
writing the calculation file might take a long time. So I am thinking of
writing a shell file to automatically do such kind of things in a command
window. By the way, I am using the unix system.
Suppose I created my problem geometry and assign the material properties and
conditions in Gid window and saved them in a folder: problem_name.gid. Then
I close gid window and go back to unix command line. How do I use the
command line to execute gid without invoking gid window to generate mesh and
write out the calculation file for problem_name.gid? In other words,
problem_name.gid has all my input files, is there a way of running gid.exe
in the command window to get my ouput file: the calculation file?
Shuo Ma
You must write a bath file with the GiD commands:
(see help on Files-Import-Batch file)
Example: batch file “mesh.bch” to read the file problem_name, generate a
unstructured mesh
with size 0.5, write the calculation file and exit:
escape escape escape files read “/tmp/problem_name” escape
escape escape escape meshing generate 0.5
escape escape escape files writecalcfile
escape escape escape quit yes
to run this batch from the command line use:
gid -b mesh.bch
You must also start GiD without any window with the parameter -n (see help
on invoking GiD for other options)
gid -n -b kk.batch
Sent: Wednesday, July 24, 2002 10:13 AM
Subject: [GiDlist] command line execution
I’ll
and
Then
and
Shuo Ma
