[GiDlist] postprocess calculation
Win98 GiD6.2.0d
I have put the .exe file in the problem.gid directory (where the .tcl file
is) and yet when I click on the menu entry nothing happens do I need Tcl/Tk
installed or is an interpreter built into GiD?
Mark
-----Original Message-----
Sent: 18 March 2002 21:57
Subject: Re: [GiDlist] postprocess calculation
‘problemtype’.bat automatically launch calc.bat with the red line
rename %2%1-1.dat %2\calc.bat
%2\calc.bat %1 %2 %3
You can also run another program (e.g. run_1.exe) directly from tcl with
Create this procedure (called by pressing your menu entry)
proc run_1 { } {
exec run_1.exe
add & to execute the process in background and continue
#exec run_1.exe &
See tcl documentation, tutorials, etc at http://tcl.activestate.com
+44 (0)1480302100
http://www.linx.co.uk/
person.
If run_1.exe is located inside the problemtype directory:
Save the parameter dir of InitGIDProjec in a global variable:e.g. VarAuxPriv(DirProblemType) to use later this path.
You can use WarnWinText “text” to debug your tcl code
proc InitGIDProject { dir } {
global VarAuxPriv
set VarAuxPriv(DirProblemType) $dir
proc run_1 { } {
#this line WarnWinText must be commented
WarnWinText “EXECUTE: $VarAuxPriv(DirProblemType)/run_1.exe”
exec “$VarAuxPriv(DirProblemType)/run_1.exe”
Sent: Tuesday, March 19, 2002 2:08 PM
Subject: RE: [GiDlist] postprocess calculation
Win98 GiD6.2.0d
Mark
proc run_1 { } {
exec run_1.exe
# add & to execute the process in background and continue
#exec run_1.exe &
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020319/67863775/attachment.htm
