GiD6.2.0d (Windows98)
Is there an easy way of having multiple different calculate options
available under a single problem type?
What I have in mind is the following:
I have a problem type and perform my calculation, but then I would like to
perform various postprocessing calculations depending on what I’m after,
using the results which have been written to the .flavia.res file. If I do
this by selecting a new problem type it warns me that all data information
(materials,conditions,data) will be lost so this is not an option. I would
like to associate a different .win.bat file with the calculate button as
selected from an options list.
I hope I am making myself clear?
Thanks in advance.
Mark
Mark Smith (E-mail).vcf
+44 (0)1480302100
http://www.linx.co.uk/
person.
Name: Mark Smith (E-mail).vcf
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020318/eca50886/attachment.obj
You can create two *.bas template files in the problem type, and with the second bas, write “on the air” the contents of a “calc.bat” file.
Then, with the standard ‘problemtype’.bat, rename the ‘problemname’-1.dat to ‘calc.bat’
and execute it:
contents of ‘problemtype’.bat:
rename %2%1-1.dat %2\calc.bat
%2\calc.bat %1 %2 %3
The contents of ‘calc.bat’ is created, for example, based on some general data values.
Sent: Monday, March 18, 2002 12:47 PM
Subject: [GiDlist] postprocess calculation
Thanks in advance.
Mark
+44 (0)1480302100
_http://www.linx.co.uk/_
person.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020318/90b13d9d/attachment.htm
Hi;
I did your sample about move nodes and it works fine. But now i want to put
more results inside the flavia.res, and give me error, please help me.
advanced thanks
Note: attached files
Pablo
Type: application/x-unknown-content-type-msh_auto_file
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021030/7d03c8b8/attachment.bin
Type: application/x-unknown-content-type-mdpxfile
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021030/7d03c8b8/attachment-0001.bin
If you define some result “OnGaussPoints”, it is necessary to define before the
location of this gauss points, (see Help-Postprocess data files-New postprocess results format)
for example:
GiD Post Results File 1.0
GaussPoints “GP1” ElemType Quadrilateral
Number Of Gauss Points: 1
Natural Coordinates: internal
End GaussPoints
Result “Cp” “movement” 1 Scalar OnGaussPoints “GP1”
Sent: Thursday, October 31, 2002 2:34 AM
Hi;
advanced thanks
Pablo
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021030/643d5964/attachment.htm
