Hello
I have downloaded the latest version of GID as well as tried different
graphic settings in Windows, but the problem with using point analysis
remains. I am using a NVIDIA 64 MB DDR GeForce3 Ti 200 graphic card.
Is there anything else I can do? Thank you.
BF
Billy Fälth
Clay Technology AB
Ideon Research Center
S 223 70 Lund, SWEDEN
Tel +46 46 286 25 81
Fax +46 46 13 42 30
www.claytech.se http://www.claytech.se/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021210/2bed403f/attachment.htm
If your problem is the related in a previous mail:
I am working with a 2-D, axisymmetric model in Code_Bright and try to make a plot (point analysis) in GID but I just get the error message “Sorry, but the point lies outside the sets”. This problem only arises when I use quadrilateral elements in the model. When I use only triangular elements, the point analysis function works well. Is there something I can do to solve this problem?
It not seems a graphic card problem.
Your “last GiD version” is the 7.1.7b? (see help-About)
Send us a small sample and briefly explains the followed steps (the selected point, etc.)
Note: can send the sample direclty to escolano at cimne.upc.es
Sent: Tuesday, December 10, 2002 2:04 PM
Subject: [GiDlist] point analysis
Hello
I have downloaded the latest version of GID as well as tried different graphic settings in Windows, but the problem with using point analysis remains. I am using a NVIDIA 64 MB DDR GeForce3 Ti 200 - graphic card. Is there anything else I can do? Thank you.
BF
Billy Fälth
Clay Technology AB
Fax +46 46 13 42 30
www.claytech.se
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021210/7042967a/attachment.htm
hi,
yes, point analysis does not work for cuadrilaterals, bug, if you don’t select
a node, but next version will do!
you can stil select nodes( right mouse button menu-selecnodes),
or join (control-A) them, to do the point analysis.
Hello
solve this problem?
/ BF
