[ GiDlist ] Please answer
I want to know if the correction (update of GiD) is available for the
bug
decribed below.
Alexandre Forest, ETS
From: “Miguel A. de Riera Pasenau” miguel at cimne.upc.es
Sent: Tuesday, March 06, 2001 5:32 AM
Subject: Re: [ GiDlist ] Border graphs
Hello Mr. Forest,
Thanks to your previous report, we could fix this bug.
A preliminary version with the correction,
will be available in one month, or less.
Meanwhile, i cannot see a way to overcome this error, as it selects
the
border
with the littlest node number.
Thanks for your help
6.3.2k1
Alexandre Forest wrote:
I have a problem with the new version (6.1.2) of GiD that I did not
experience
with v.5. That is:
When generating a 3D mesh consisting of a box enclosing a wing that
is
attached to one of its side, I want to create border graphs of the
wing
sections.
In v.5, I would generate some sections cuts, then I was able to
select
the
wing section only, and not the square (that was generated by cutting
the
wing
and the box enclosing it) that is part of the cut.
In v.6.1.2, it seems that it is impossible to separate the wing
section
from
the rest of the cut for the purpose of a border graph.
Can you help?
Alexandre Forest
ETS
Miguel A. de Riera Pasenau miguel at cimne.upc.es
http://gid.cimne.upc.es
