Hello
Im new to GiD and Im basically performing analysis using OpenSees for my thesis and I would like to use GiD. Any idea about any useful material that I can use to be able to understand how to present OpenSees model and the obtained results using GiD? Thanks.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140727/c9811aaf/attachment.htm
An old flavia writer for OpenSees, but, still useful
http://opensees.berkeley.edu/wiki/index.php/GiD_ProblemTypes_for_2D_Slope_An
alysis_Input_File_Generation
[mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of AbdelRhman 109891
Sent: Saturday, July 26, 2014 11:24 PM
Subject: [GiDlist] OpenSees
Hello
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140727/25272a93/attachment.htm
There is an unofficial interface done by Pedro Arduino from University
of Washington in Seattle. You can find more information:
and
Hope it help, regards.
Adrià
El 27/07/2014 8:23, AbdelRhman 109891 escribió:
Hello
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140728/7a325caf/attachment.htm
Hello!
I’m using Quad9 elements and when I create a contact surface it is also meshed with Quad9 elements.I’d like to know if there is any way for creating a contact element that would only use the pre-existing nodes from the surfaces that are in contact, therefore generating a contact element with 6 nodes (instead of 9).
Thanks in advance!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140727/59c76956/attachment.htm
Nowadays the Quadratic is a global variable, then the whole mesh is
quadratic or lineal, but it is not possible to generate a mix of them
And the Quad6 element doesnt exists in GiD (quadratic in a direction and
linear in other direction)
The only options you have is to set the contact surface to not be meshed,
and then you will not have any contact element, but already continue forcing
the 1-to-1 relationship between neighbor nodes, or set this surface to be
meshed with line elements and instead of having Quad9 you will have
Line3 in this contact surface (a line element linking neighbor nodes but
already quadratic)
You can ignore for your calculation the unwanted quadratic nodes of contact
elements.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de David R. José
Enviado el: domingo, 27 de julio de 2014 18:40
Asunto: [GiDlist] Contact element
Hello!
Thanks in advance!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140728/b3ae99d3/attachment.htm
