Dear sir,
I had a problem in meshing a contact volume it is giving a
figplex error.My geometry is a 2 solid cylinders with 2 different materials.
do you have any document to show how to mesh contact volumes.
thanking you sir
Srikanth
IIT Kanpur
Can you send the GiD model to test it?
(compressed with a single extension: e.g .zip instead .gid.zip )
Sent: Thursday, November 16, 2006 8:00 AM
Subject: [GiDlist] opensees gid
Dear sir,
thanking you sir
Srikanth
IIT Kanpur
Hello Gid-Team,
i want to visualize Streamlines on a mesh composed of quadratic bricks.
Do you plan to implement that? Currently only tets and triangles are
possible for that task
Is there a workaround?
Gerhard
/ // /// Friedrich-Alexander-Universität Erlangen
_/ _/ _/ Paul-Gordan-Str. 3-5, D-91052 Erlangen
_/ _/ _/ Friedrich-Alexander University Erlangen
_/ _/ / / Department of Sensor Technology
/// // /// Paul-Gordan-Str. 3-5, D-91052 Erlangen
Gerhard Link, M.Sc.
email: Gerhard.Link at lse.eei.uni-erlangen.de
phone: +49-9131-85-23149
fax: +49-9131-85-23133
Hello Gerhard,
We are planning to add streamlines for hexahedra, prisms and pyramids in a
short term: if not for the next beta version, surely for the next next one.
The only way around that comes to my mind is to convert the hexahedra into
tetrahedra.
Miguel
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Gerhard Link
Enviado el: jueves, 16 de noviembre de 2006 9:43
Asunto: [GiDlist] Streamlines
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
Hallo
Now i remembered how to split elements, but sadly a 20 node brick can
not be splitted.
Is it possible to delete only all elements and create a tetra mesh out
of the nodes?
Gerhard
Miguel Pasenau wrote:
Hello Gerhard,
tetrahedra.
Miguel
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
Hallo,
If the hexahedra could have 27 nodes then it would be easier, we don’t have
to create the middle face nodes.
Then we can only use the vexter of the hexaedra to get the tetras and add to
those tetras the middle edge nodes.
Miguel
Enviado el: jueves, 16 de noviembre de 2006 19:04
Asunto: Re: [GiDlist] Streamlines
Hallo
not be splitted.
of the nodes?
Gerhard
Hello Gerhard,
one.
tetrahedra.
Miguel
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
Warning: This message has had one or more attachments removed.
Warning: Please read the “VirusWarning.txt” attachment(s) for more information.
Hallo
if you want to test splitting 20 node brick elements
here is my mesh
Thanks in advance
Gerhard
Hello Gerhard,
tetrahedra.
Miguel
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
This is a message from the MailScanner E-Mail Virus Protection Service
The original e-mail attachment “PESegQCFac3.post.msh”
is on the list of unacceptable attachments for this site and has been
replaced by this warning message.
If you wish to receive a copy of the original attachment, please
e-mail helpdesk and include the whole of this message
in your request. Alternatively, you can call them, with
the contents of this message to hand when you call.
At Thu Nov 16 19:14:27 2006 the virus scanner said:
Attempt to hide real filename extension in PESegQCFac3.post.msh
Note to Help Desk: Look on the MailScanner in /var/spool/mailscanner/quarantine (message kAGIE7Hv028096).
Postmaster
I received this message:
Postmaster
The problem lies with the double extension ¿can you send me the mesh in a
zip file, or a .tgz? or just with on extension
Miguel
Enviado el: jueves, 16 de noviembre de 2006 19:07
information.
Hallo
here is my mesh
Thanks in advance
Gerhard
Hello Gerhard,
one.
tetrahedra.
Miguel
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
Hi Miguel,
now here come me zipped meshes.
i included also a quadr mesh, because i need streamlines on that as well.
Gerhard
Postmaster
Miguel
information.
Hallo
here is my mesh
Thanks in advance
Gerhard
Hello Gerhard,
one.
tetrahedra.
Miguel
Hello Gid-Team,
Gerhard
Gerhard Link, M.Sc.
Type: application/x-compressed-tar
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20061117/520d384a/attachment.bin
i try to make some mesh for ELMER and your programm worked very well. I need the
mesh for some blood simulations that i do in a projekt in my univesity.
but now i have a problem i never had before.
By pressing the button “generate mesh” i get the message
Couldn´t map this point
What can i do that it will work?
i send a picture of my monitor and the problem file and hope you can help me!
regards martin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20061117/c61effea/attachment.obj
Hello Martin,
We have detected a bug in the internal definition of the surface inside GiD,
but we need to create the surface following the same steps as you to be able
to correct it. Please, could you send us the initial mesh from which you
have created the SurfMesh?
ABEL
Abel Coll Sans
Office C2 - C1Building - Campus Nord UPC
Tfn: 34 - 93 401 74 03 Fax: 34 - 93 401 65 17
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de MArtin Koske
Enviado el: viernes, 17 de noviembre de 2006 15:21
Asunto: [GiDlist] [Problem] couldn´t map this point
the
me!
regards martin
hello Abel,
this is the original mesh.
it is an .stl file.
i converted it with
create - surface mesh
create - Volume - By contour
Regards Martin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20061121/8892d9d2/attachment.obj
Hi Martin,
Finally we have found the bug and we have fixed it. Next beta and official
versions won’t have this problem no more.
Thank you so much for notifying us this irregular behaviour.
ABEL
P.D: I have corrected the GiD model you sent, and GiD is able to mesh all
its surfaces. If you want it, just send me an e-mail and I will send it to
you.
Abel Coll Sans
Enviado el: martes, 21 de noviembre de 2006 12:54
Asunto: Re: [GiDlist] RE: [GiDlist] [Problem] couldn´t map this point
hello Abel,
it is an .stl file.
i converted it with
Regards Martin
Hi Abel,
can you send me this corrected gid model.
thanks for reparing it.
regards Martin
Zitat von Abel Coll abelcs at cimne.upc.edu:
Hi Martin,
ABEL
you.
Abel Coll Sans
hello Abel,
it is an .stl file.
i converted it with
Regards Martin
Here you are.
ABEL
Abel Coll Sans
Enviado el: martes, 28 de noviembre de 2006 15:17
Hi Abel,
regards Martin
Hi Martin,
ABEL
you.
Abel Coll Sans
hello Abel,
it is an .stl file.
i converted it with
Regards Martin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20061128/7a01dbca/attachment.obj
