[ GiDlist ] Normal vector definition + Layers and meshing
Hi !
We have recently purchased Gid 5.0 p47 for WinNT and we are trying to
perform surface meshing (structured mesh with triangular elements) of
imported CAD surfaces (IGES format) with it. Then, we export the
generated mesh in a file (using the ‘Write Mesh’ command) in order to
have it processed by another program. Doing this, we have two problems :
  1. Our program tries to build the normal vectors of each of the triangle
    elements but it seems to us that the normal vectors are not oriented in
    the same direction, even if the elements originated from the same
    initial CAD surface (and this is really a problem for us). We build the
    normal vector using the 3 consecutive nodes defining the triangle in the
    exported mesh file of GiD. As far as we are concerned, it is the order
    of the nodes which matters to define the direction of the normal vector.
    Does GiD take care of node ordering when writing mesh data ? Is there a
    way to correct this ?
  2. We have grouped NURBS surfaces in layers before meshing them.
    Everything works fine : the triangle elements still belong to different
    layers after meshing (the same as their CAD counterparts) but we
    couldn’t have GiD to write this information in the Mesh file. We were
    expecting GiD to add a number (defining the group) at the end of each
    line of nodes (as explained in the reference manual) but it doesn’t.
    What’s happening ?
    Hope we’ll get answers.
Thanks in advance,
Gilles.
Gilles LACROIX | mailto: lacroix at bertin.fr
Bertin Technologies
