I have two groups of nodes related to different elements,
let’s say from 1 to 20 related to plane quadrilateral elements
and from 21 to 30 related to linear beam elements.
How is it possible to write them separately in the bas file?
andrea
andrea
You can define and apply for example some additional condition to the source lines/surfaces to be transferred over nodes on the
mesh,
and then you can made a loop over the nodes of this conditions.
You can also use two layers to separate this entities.
Sent: Thursday, August 03, 2006 5:10 PM
Subject: [GiDlist] node of different elements
andrea
Andrea Mordini VCE Holding GmbH
Civil Engineer, Ph.D. Hadikgasse 60
Phone: (+43 1) 897 53 39 1467 A-1140 Vienna - Austria
mordini at vce.at Fax.: (+43 1) 893 86 71
http://www.andreamordini.com http://www.vce.at
In a .bas template you can do it with *set elems() and then doing a loop on these elements,
something like this:
*Set elems(Linear)
*Loop elems
*elemsnum *elemsmat *elemsconec
*End elems
*Set elems(Quadrilateral)
*Loop elems
*End elems
