[GiDlist] Node Numbering convention in GiD
Hi Guys
If any of you happened to know about node numbering
convention for element connectivity in GiD..especially
for 4 node and 8 node shell element..I’m still
confused with that..My previous FEM is such:
.s .s
2…1 2…5…1
. …r 6. …8…r
3…4 3…7…4
4 node 8 node
How we could make it satisfied with our own previous
Convention??
Do You Yahoo!?
Yahoo! Health - Feel better, live better
hi,
the conectivities are the ones described in:
http://gid.cimne.com/support/gid_16.subst#cuad4.gif
http://gid.cimne.com/support/gid_16.subst#cuad8.gif
http://gid.cimne.com/support/gid_16.subst#cuad9.gif
you can also create a quadratic quadrilateral mesh
example in gid(pre), do a label all nodes and
list one of the elements (utilities-list-elements)
and you’ll get the ordering of the nodes in gid.
i think this match with your description, or not?
Vilaysak Sayakoummane wrote:
Hi Guys
.s .s
2…1 2…5…1
. …r 6. …8…r
3…4 3…7…4
4 node 8 node
Convention??
Do You Yahoo!?
http://health.yahoo.com
Hi Guys..
Thank Miguel for your response..
Another thing for me that I want to know is: We can
create a new menu inserted into the main menu of
GiD..What about if after having created the new menu
name for example “Fanthom” then I want to move all my
problem type to this menu..HOw we can make it work..
Usually the problemtype_name(Fanthom.gid) is working
only when it is contained in Problemtype directory of
original gid.
Regards..
Willy.
Do You Yahoo!?
How to create and modify the GiD menus are described in our web site,
under ‘Support-On-line Manual-TclTk Extensions: Managing menus’:
http://gid.cimne.com/support/gid_17.subst#SEC255
To do so, a file called, in your case, ‘Fanthom.tcl’ should be present
inside the ‘Fanthom.gid’ problem-type directory.
To modify/create the menus when you problem type is loaded, you should
define the function
proc InitGIDProject { dir } {
…body(1)…
which will be executed when the problem type is selected from within GiD,
or when called like ‘gid -p fanthom.gid’ to load the problem type
automatically when starting GiD, ( do ‘gid -help’ for more information).
Inside the ‘InitGIDProject’ procedure you have to call following functions:
· reateMenu new_menu_name PRE/POST/PREPOST -------- to create the menu
· InsertMenuOption menu_name option_name position command PRE/POST/PREPOST ------ to add options
· RemoveMenuOption menu_name option_name PRE/POST/PREPOST -------- to delete a menu option
· UpdateMenus ------- so the menu bar is rebuild to reflect the changes made before.
hope it helps,
Hi Guys..
original gid.
Regards..
Willy.
Do You Yahoo!?
Hi Miguel
Thanks so much for replying. I have done with the
new menu and all submenu but when clicking on those
submenus it didn’t work at all..Not like when clicking
under Problemtype. How can we make it work. How can
those submenu communicate with GiD???
— “Miguel A. de Riera Pasenau” miguel at cimne.upc.es
in our web site,
under 'Support-On-line Manual-TclTk Extensions:
Managing menus’:
_http://gid.cimne.com/support/gid_17.subst#SEC255_
should be present
loaded, you should
define the function
…body(1)…
problem type
to create the menu
hope it helps,
Hi Guys..
can
menu
my
work..
working
of
original gid.
Regards..
Willy.
Do You Yahoo!?
Do You Yahoo!?
here you have an example: TclTkExample.tgz
which add a menu, with two options:
‘Window popup’ with show a window that creates a quadrilateral
‘status’ which gets the number of lines from gid.
more information about the Tcltk GiD commands can be found
under
GiD online manual-Tcl-Tk extension-Control functions
at
http://gid.cimne.com/support/gid_17.subst#SEC252.
You can find also TclTk man pages and tutorials at
http://gid.cimne.com/ManHtml/index.html
hope it helps,
Hi Miguel
in our web site,
Managing menus’:
should be present
loaded, you should
define the function
…body(1)…
problem type
to create the menu
hope it helps,
Hi Guys..
can
menu
my
work..
working
of
original gid.
Regards..
Willy.
Do You Yahoo!?
Do You Yahoo!?
Type: application/x-tgz-compressed
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020802/5f516f2d/attachment.bin
Hi there
Thank Miguel and Ramon for your replying. Miguel
thank again for your attached files. In addition, what
I need to know more are:
  1. How all the files,refer to your ProblemType
    tclTkExample files, (TclTkExample.cnd,
    TcltkExample.prb, clTkExample.mat, TclTkExample.bas,
    and so on. These files are standard file in
    problemtype_name) work in this new Menu
    TclTkExample.
  2. Can we have TclTk file in the Problemtype_name more
    than 1? in case I need to create more windows and more
    modifications? if this file could be only 1 name then
    it would be to big to get lost easily.
  3. How can we make ProblemType_name files as hidden
    files,. in case we don’t want the Users see our source
    codes.
  4. How could we avoid having all the files like files
    .cnd, *.prb, *.mat, *.unit rewritten again in the
    project_name files. For example, I run my project
    problem in my problemType_name (Fanthom.gid) and I
    save the project problem as “cantilever.gid”.. After
    clicking Calculate then I got the results..In this
    folder cantilever.gid, why I still have those files
    cantilever.cnd, cantilever.prb, cantilever.mat
    actullay those files are unnecessary to be written out
    again. This is waste of computer memories. Do you have
    any option to avoid having those files written out
    again?
Do You Yahoo!?
hello,
  1. i just put an empty .prb file so that gid recognizes
    the TclTkExample.gid as a problem type.
    I didn’t define any condition, materials nor problem
    data, so the other files are not needed.
    ( .cnd, .bas, .mat, .bas)
  2. Sure, you can have as many tcl files as you want, but
    remember to use the ‘source’ tcl-command in your
    ‘proc InitGidProject {}’ routine. For examle:
YourProblemType.tcl:
set YourProblemTypeDirectory $dir
source [ file join $YourProblemTypeDirectory AnotherTclFile1.tcl]
source [ file join $YourProblemTypeDirectory AnotherTclFile2.tcl]
source [ file join $YourProblemTypeDirectory AnotherTclFile3.tcl]
This ‘source’ command reads and executes the contents of these files,
so if you define procedures/functions/commands inside these files,
after the ‘source’ command you can use them.
  1. by now there is no way to make tcl-files hidden to the user, or to
    encrypt them.
    One way is to have the tcl-files encrypted and let the ‘InitGIDProject’
    call an external program do unencrypt them, make the ‘source’, and
    delete the unencrypted files. Once the ‘source’ command is issued,
    the other tcl-files are not longer needed, so you can delete them.
    set old_dir [ pwd]
    cd TemporaryDirectory “YourTemporalDirectory”
    foreach file “AnotherTclFile1.tcl AnotherTclFile2.tcl AnotherTclFile3.tcl” {
    set abs_file [ file join $YourProblemTypeDirectory $file]
    set tmp_file [ file join $TemporaryDirectory $file.tmp]
    exec [ file join $YourProblemTypeDirectory Unencrypt] $abs_file $tmp_file
    source $tmp_file
    file delete $tmp_file
    cd $old_dir
  2. the reason for the files to be present is to allow user to view, mesh the
    project on another machine, or pass the example to another colegue,
    to view the materials assignement, conditions, problem data, and so on,
    with no need to copy the whole problem type.
    Also avoids compatibility problems which surely appears when something
    is changed in the conditions, materials or problem data of the problem
    type and the data from the project can not be matched with the new rules.
    Instead of having a useless project, with this method you still have a
    useful and working project. There is a posibility to change, actualize
    the problem type of an old project inside GiD.
    Note that nor the .tcl files, nor the calculation executable are copied
    to the project.gid directory.
    beside this, the size of these files is insignificant to the sizes of
    the .msh, .geo or the .dat file of a big project ( thousand of surfaces
    or millions of elements).
hope it helps.
Hi there
TclTkExample.
codes.
again?
Do You Yahoo!?
Hi
Thank Miguel for your last reply. YOu didn’t get my
point but your reply is so valuable anyway. I attached
file for you so that you may understand how I would
like to do..
Do You Yahoo!?
Name: New Problemtype menu.zip
Desc: New Problemtype menu.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020807/684fa658/attachment.bin
This is what you mean?
(look at the ‘InsertMenuOption’ paragraph)
hope it helps
Hi
like to do..
Do You Yahoo!?
New Problemtype menu.zip Type: Zip Compressed Data (application/x-zip-compressed)
Encoding: base64
Description: New Problemtype menu.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020809/adef4d2a/attachment.bin
Hi there
Thank Miguel for your reply. I’ll try it as you
adviced,especially I have to look on TclTk part
deeply.
Another small thing I would like to ask again is:
in my Problemtype.bas file I used *CondNumEntities
to get number of nodes that assigned Loads on it. When
I assigned the different loads on the same one node
then I get number of Point load equals only 1. For
example, on node #53 I assigned Load Fx=10, Fy=20,
Mx=45,My=60 then my data file result is:
Number of Point Load = 1 (usually should be 4)
Node number Fx Fy Fz Mx My Mz
53 10 20 0 45 60 0
I try to use *set cond Point_Load *CanRepeat but I
didn’t get the number of Laods equals 4.
How can we solve this problem?? I am sure that it
should be some command to deal with this??
Regards.
Do You Yahoo!?
HotJobs - Search Thousands of New Jobs
*condnumentities count the number of entities with an applied contition, and Fx, Fy, … are fields of the same condition
Use an auxiliary loop to count the number of fields with not zero value
example: (for a condition named Point-Load, and fields named Fx, Fy, etc)
*set var cont=0
*set cond Point-Load *nodes *canrepeat
*loop nodes onlyincond
*if(cond(Fx,real)!=0)
*set var cont=operation(cont+1)
*endif
*if(cond(Fy,real)!=0)
*endif
*if(cond(Fz,real)!=0)
*endif
*if(cond(Mx,real)!=0)
*endif
*if(cond(My,real)!=0)
*endif
*if(cond(Mz,real)!=0)
*endif
*end nodes
Nº total= *cont
From: “Vilaysak Sayakoummane” vilaysako at yahoo.com
Sent: Monday, August 12, 2002 5:01 AM
Subject: Re: [GiDlist] Re: [GiDlist]New Menu
Hi there
deeply.
53 10 20 0 45 60 0
Regards.
Do You Yahoo!?
http://www.hotjobs.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020812/0eb6df59/attachment.htm
Hi Enrique
Thanks so much for your immediate reply. I got
ideas from your advice and I’ll apply to other
problems too.
Many thanks..
the same condition
with not zero value
*set var cont=0
*endif
*endif
*endif
*endif
*endif
*endif
*end nodes
Nº total= *cont
Hi there
deeply.
*CondNumEntities
When
node
53 10 20 0 45 60 0
I
Regards.
Do You Yahoo!?
Do You Yahoo!?
Hi all GiDs
I have problem with GiD.7 when trying to write the
CalFile. I have no problem when using with GiD6.2 but
when transferring my ProblemType to GiD.7 I noticed
that so many options included.
In problemType_name.mat, in GiD.7 allows only 100
fields. Actually my fields (QUESTION:) are more than
100. My question is:
  1. Do you have any option to ovoid this limitation?
  2. In case I have more fields in this
    ProblemType_name.mat file. Can GiD allow to have more
    than 1 file of ProblemType_name.mat file?
  3. If not from two listed above how should we solve
    this problem?
Best regards.
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
The maximum number of fields of a material has not been reduced from version
6.2 to 7.x
Please, send us your problem type, and a small example, to detect the
problem.
(can send if prefers directly to escolano at cimne.upc.es)
Sent: Monday, August 26, 2002 6:47 AM
Hi all GiDs
this problem?
Best regards.
Do You Yahoo!?
http://finance.yahoo.com
Hi
Thank Enrique, I’ll send the files to you through
your mail later for the Mat file. Now I just want to
check it again whether because of Mat file or bas
file.
Other questions are:
I just want to know if GiD can process the command
DEPENDENCIES across the fields in the BOOK: to
other fields or TITLE in other BOOKs??
as I tried DEPENDENCIES can only be effective inside
the same BOOK by using TITLESTATE:TITLE
command..not BOOK to BOOK
  1. HOw we use the DEPENDENCIES across the Windows to
    other windows (BOOK to BOOK) in ProblemType files?
  2. I tried to read the BackgroundMesh but nothing
    shows up. HOw this thing really works out? there is
    not enough info yet about this in the online document.
Thanks in advance.
Best Regards
Willy
Do You Yahoo!?
  1. It is not available at this moment, to access with dependencies across
    fields of different materials, conditions or problem data.
    This must be enhanced for future versions.
  2. The background mesh is not showed to the user, it is used only to assign
    sizes for the new mesh.
    To view this background mesh shape, you can read as mesh with
    Files-Import-GiD Mesh (mesh sizes are ignored)
    To view the assigned sizes for test pourposes, you can write an auxiliar
    postprocess result file, with the desired size as scalar result, and read it
    in GiD postprocess.
Sent: Friday, August 30, 2002 7:05 AM
Subject: [GiDlist] Using DEPENDENCIES:
Hi
file.
Thanks in advance.
Best Regards
Willy
Do You Yahoo!?
Check options:
CANREPEAT: yes
in .cnd file
and *CanRepeat in .bas file
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Vilaysak
Sayakoummane
Enviado el: lunes, 12 de agosto de 2002 5:02
Asunto: Re: [GiDlist] Re: [GiDlist]New Menu
Hi there
deeply.
53 10 20 0 45 60 0
Regards.
Do You Yahoo!?
Hi there
Please give your advice!!!
I’m working on “Pressure Load” for Solid element.
How can we have GiD to select the Face of the solid
element??is there any possibility? in my file .cnd, I
used
CONDTYPE:over surfaces
but when selecting the element it was selected as a
whole element not a surface (or face of element). How
we deal with this kinda problem?
Best regards.
Do You Yahoo!?
The condition must be defined over face elems, not over body elems
CONDMESHTYPE:over face elems
It is best assign the conditions over the geometry (surfaces), not over the elements directly.
If you draw this condition only is coloured the selected faces.
You can list the faces in the bas file with *globalnodes or *localnodes (inside a loop elements onlyincondition)
Sent: Wednesday, August 14, 2002 1:04 PM
Subject: [GiDlist] HOw to select a face of a Solid element
Hi there
used
Best regards.
Do You Yahoo!?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020828/d5f625b4/attachment.htm
