[GiDlist] (no subject)
hi i´m spanish student who need to use the gid for a project.
can anyone tell me all the steps to accomplished the creation of the
.sim file, and how can i linked to the .geo that it makes reference to?
this was what i wrote
.sim file
cond DESLIZADERA
1
global
cond(int,1)
1
0
0
proyecto.geo
.cnd file
NUMBER: 1 CONDITION: DESLIZADERA
CONDTYPE: over points
CONDMESHTYPE: over nodes
QUESTION: DESPLAZAMIENTO_Y
VALUE: 1
END CONDITION
my problem type name is proyecto.gid, when i´ve the .geo with the .cnd
.prb .mat and .sim in the problem type folder, i can´t load the problem
type the message is that it doesn´t exist such a problem type,
and when the .geo isn´t in the folder, when loading the problem type, it
says that there is an error in line 8 of the .sim file, that which
refers to the .geo file proyecto
thanks
—Publicidad--------------------------------------------------------
Juega con Ventura24.es, lotería inteligente y multiplica tus
posibilidades!! Última información publicada - iespaña
Not use the same name as the problem type (in your case ‘proyecto’) for the
.geo symbol file,
because it creates a confusion between a model and a problem type.
Use for example another name as “deslizadera.geo”.
From: “tarzan delasmonas” tarzandelasmonas at iespana.es
To: GiDlist at gatxan.cimne.upc.es&gt tarzandelasmonas at iespana.es
Sent: Sunday, December 22, 2002 12:32 PM
.sim file
cond DESLIZADERA
1
global
cond(int,1)
1
0
0
proyecto.geo
.cnd file
VALUE: 1
END CONDITION
thanks
_posibilidades!! Última información publicada - iespaña
Hello;
I would like to use RamDebugger with GID under windows, so i have to modify
a file Tcl-opengl (help ramdebugger), and load comm, but i have not idea how
i do it. Can you help me??, i have to do with remote mode, i have to open
gid??.
A lot of thanks.
Pablo
To use RamDebugger with GiD, do the following:
-Install RamDebugger
-Open with an editor file ‘tclfile-opengl’ located
in directory ‘scripts’ inside GiD distribution
  • Add the following lines near the end of the file:
    lappend auto_path {C:\TclTk\RamDebugger\addons}
    package require commR
    comm::register gid 1
Note1: near the end of the file, means before the last line
with command ‘return’
Note2: substitute: C:\TclTk\RamDebugger\addons for the place
where you have installed RamDebugger
Once everything is done, if GiD is open and you open
RamDebugger, GiD should appear in the ‘File-Debug on’ menu
Best regards and happy new year,
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Pablo Perez del
Castillo
Enviado el: martes, 31 de diciembre de 2002 1:55
Asunto: [GiDlist] use RamDebugger
Importancia: Alta
Hello;
gid??.
A lot of thanks.
Pablo
