[GiDlist] new feature in DEPENDENCIES field (experimental)
As we have received some request about accessing to properties field
of other windows (not only local field) using DEPENDENCIES, here we
announce an experimental feature implemented in GiD (7.1 and above).
Now is able to reference fields of other window using what we call
‘global field reference’. A global reference is a field cualified with
the ‘data set’ where it belongs. The data set are, for now: CONDITIONS
and PROBLEM DATA.
-Referencing CONDITIONS:
A global reference to this data set is conditions.cndname.field or
cndname.field if we are referencing from one condition to another.
  • Referencing PROBLEM DATA:
A global reference to this data set is gendata.field
  • An example.
Here is an example (the problemtype is also attached):
NUMBER: 1 CONDITION: Load
CONDTYPE: over points
CONDMESHTYPE: over nodes
QUESTION: Fx
VALUE: 0
QUESTION: Fy
VALUE: 0
QUESTION: Fz
VALUE: 0
QUESTION: Field_1
VALUE: 1
QUESTION: Field_2
VALUE: 2
END CONDITION
PROBLEM DATA
QUESTION: STATE_Field1:#CB#(NORMAL,DISABLED,HIDDEN)
VALUE: NORMAL
DEPENDENCIES: (NORMAL,RESTORE,Conditions.Load.Field_1,1)
DEPENDENCIES: (DISABLED,SET,Conditions.Load.Field_1,1)
DEPENDENCIES: (HIDDEN,HIDE,Conditions.Load.Field_1,1)
QUESTION: STATE_Field2:#CB#(NORMAL,DISABLED,HIDDEN)
VALUE: NORMAL
DEPENDENCIES: (NORMAL,RESTORE,Conditions.Load.Field_2,2)
DEPENDENCIES: (DISABLED,SET,Conditions.Load.Field_2,2)
DEPENDENCIES: (HIDDEN,HIDE,Conditions.Load.Field_2,2)
END PROBLEM DATA
Finaly we remind that this is an experimental and not documented feature.
best regards,
Jorge Suit.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020926/b8e6d65b/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020926/b8e6d65b/attachment.obj
