[ GiDlist ] Nastran export
You cannot calculate directly with Nastran from GiD. Instead,
you must use:
Files-Export-Write calculation file
and you will obtain the input data file for NASTRAN.
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Olivier Bounhoure
Enviado el: viernes, 08 de junio de 2001 11:28
Asunto: [ GiDlist ] Nastran export
Hello everybody,
I’ve got some troubles using the Nastran problem types : I define geometry,
meshing, materials, conditions and problem data but when I clic on
calculate,
there is always the same error : in the warning window, “Error executing
‘/…/problemtypes/nastran_plane.gid/nastran_plane.bat /…/file.gid
/…/problemtypes/nastran_plane.gid’” and in the info windows, “Problem with
calculate program Erreur de format pour exec() check script file.2”.
Can anybody tell me if I do something wrong or if I have some software
installation troubles?
Thanks in advance
Olivier
