[GiDlist] multiple postprocessing
I ’ d like to know if is it possible to visualize more than one result
set at
the same time in a postprocessing sesion.
For example, I want to see a vector field superimposed with a scalar field
at the same time.
Thanks in advance
With GiD 7.x it is possible to show several results superimposed with the
“Several Results” window:
menu: Windows-Several Results:
Select “one over another” option and draw the desired results.
The window show the current list of results to draw. It is possible to
delete some result.
Sent: Thursday, November 21, 2002 5:02 PM
Subject: [GiDlist] multiple postprocessing
set at
at the same time.
Thanks in advance
I have some troubles with my screen when using GiD 7.0 probably due to the
screen card.
My system is Win2000 pro and is running on a notebook (HP omnibook XE3)
Have you some suggestions to solve my problem ?
Thanks.
Zoubir Khatir,
Laboratoire des Technologies Nouvelles (LTN)
INRETS, 2. Av. Malleret-Joinville, 94114 Arcueil Cedex
Tel: (33).01.47.40.73.34 Fax:(33).01.45.47.56.06 mail: khatir at inrets.fr
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021202/53529356/attachment.htm
See the F.A.Q (Frequently asked questions) http://gid.cimne.com/support/faq_8.subst
I try to open GiD by the first time on MS Windows and it crashes
Tipically, these type of problems are caused by the graphics acceleration card.
A possibility to avoid the problem is the following: Try to start GiD safe mode (from the start menu) and activate use Software OpenGL If the problem persists, try to deactivate the graphic hardware acceleration (Screen properties-Advanced options). Also try a different colour resolutions (select 32 bits of colour for example) Search in the web page of your card if there are actualized drivers for your graphic card.
Sent: Monday, December 02, 2002 4:19 PM
Subject: [GiDlist] screen troubles
I have some troubles with my screen when using GiD 7.0 probably due to the screen card.
Thanks.
Zoubir Khatir,
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021202/e6735bd2/attachment.htm
Hi GiD support,
I’m trying to display some values with “contour fill” on my gauss points
in the post-processor. I have all triangular elements and I have
defined 3 gauss points per element, one on each side of the triangle.
In the *.flavia.res file I have listed the element_number, value_1,
value_2 and value_3 for each of my elements. But I have a question:
How do you arrange the order of the sides of an arbitrary triangular
element? This is important since my output values are distinct for
each side (or edge) of the an triangular element. My main goal is to
display a value on each edge, which is defined by two global nodes.
Just for you info.
Thankyou for your help.
Tom
Thomas Chan
Research & Development Engineer
EMAG Technologies, Inc.
tkchan at emagtechnologies.com
