After taking a look into your files i found following problems:
in the ‘es04.flavia.msh’ file:
· the first mesh you are defining has triangles of 4 nodes:
MESH “Only_coordinates” Dimension 2 ElemType Triangle Nnode 4
it should be:
MESH “Only_coordinates” Dimension 2 ElemType Triangle Nnode 3
in the ‘es04.flavia.res’ file:
· the gauss points name “Quad4_4_GP” must be also given for the
results that are defined over gausspoints:
Result “Stress” “Titolo” 1 Matrix OnGaussPoints
shoud be:
Result “Strains” “Titolo” 1 Matrix OnGaussPoints “Quad4_4_GP”
· The last result, is defined as a ‘matrix’ result, but it seems to be a ‘scalar’ one:
Result “History_Variables” “Titolo” 1 Scalar OnNodes
Values
1 1.5183E-02
should be:
Result “History_Variables” “Titolo” 1 Matrix OnNodes
Values
1 1.5183E-02
· there are results with the same name inside the same step/analysis, this will
bring some problems inside GiD, it is better to give them unique names inside the
same step and analysis:
Result “Stress” “Titolo” 1 Matrix OnNodes
Result “Strains” “Titolo” 1 Matrix OnNodes
Result “Stress” “Titolo” 1 Matrix OnGaussPoints “Quad4_4_GP”
can be changed into:
Result “Stress PG” “Titolo” 1 Matrix OnGaussPoints “Quad4_4_GP”
Result “Strains PG” “Titolo” 1 Matrix OnGaussPoints “Quad4_4_GP”
I send you enclosed the corrected files too,
hope it helps
Aldo Ghisi wrote:
I’m trying to use the new postprocess format files with GiD 6.1.5b, but
with the program finds some errors. I attached them in the file errors.txt
You can find also my .flavia.msh and .flavia.res file in the attachments.
I tried also with GiD 6.1.4b, but I had the same result.
Where are my errors?
Thank you in advance.
ALDO GHISI
Politecnico di Milano
Tel.: +39 02 2399 4218
Fax.: +39 02 2399 4220
Coordinates
1 0.0000 0.0000
2 0.0000 3.0000
3 3.3333 0.0000
4 3.3333 3.0000
5 0.0000 6.0000
6 6.6667 0.0000
7 3.3333 6.0000
8 6.6667 3.0000
9 6.6667 6.0000
10 0.0000 9.0000
11 3.3333 9.0000
12 10.0000 0.0000
13 10.0000 3.0000
14 6.6667 9.0000
15 10.0000 6.0000
16 0.0000 12.0000
17 3.3333 12.0000
18 10.0000 9.0000
19 6.6667 12.0000
20 0.0000 15.0000
21 3.3333 15.0000
22 10.0000 12.0000
23 6.6667 15.0000
24 10.0000 15.0000
End coordinates
Elements
no elements entered, they will be in the successive meshes
End elements
Mesh “Quad4_4_GP” Dimension 2 ElemType Quadrilateral Nnode 4
Coordinates
no coordinates entered, they are already in the first mesh
End coordinates
Elements
1 16 17 21 20 1
2 10 11 17 16 1
3 5 7 11 10 1
4 2 4 7 5 1
5 1 3 4 2 1
6 17 19 23 21 1
7 11 14 19 17 1
8 7 9 14 11 1
9 4 8 9 7 1
10 3 6 8 4 1
11 19 22 24 23 1
12 14 18 22 19 1
13 9 15 18 14 1
14 8 13 15 9 1
15 6 12 13 8 1
End elements
GiD Post Results File 1.0
GaussPoints “Quad4_4_GP” ElemType Quadrilateral “Quad4_4_GP”
Number of Gauss Points: 4
Natural Coordinates: Internal
End GaussPoints
Result “Displacements” “Titolo” 1 Vector OnNodes
Values
1 0.00000E+00 0.00000E+00
2 -8.68265E-02 -1.24237E-01
3 5.37876E-03 -5.09983E-02
4 -6.33872E-02 -4.13041E-02
5 -2.22165E-01 -2.04029E-01
6 5.36386E-03 5.17301E-02
7 -2.00874E-01 -6.22429E-02
8 -6.28153E-02 4.18077E-02
9 -1.98838E-01 6.11654E-02
10 -3.95046E-01 -2.55700E-01
11 -3.81417E-01 -8.26849E-02
12 0.00000E+00 0.00000E+00
13 -8.58337E-02 1.24311E-01
14 -3.76272E-01 7.58024E-02
15 -2.18611E-01 2.05511E-01
16 -5.84841E-01 -2.79543E-01
17 -5.83995E-01 -9.49781E-02
18 -3.90427E-01 2.65639E-01
19 -5.89806E-01 7.77479E-02
20 -7.65915E-01 -2.84102E-01
21 -7.72990E-01 -9.45430E-02
22 -5.92154E-01 3.11218E-01
23 -8.13117E-01 8.88679E-02
24 -9.14073E-01 3.52634E-01
End Values
Result “Velocities” “Titolo” 1 Vector OnNodes
Values
1 0.00000E+00 -8.68265E-02
2 -1.24237E-01 5.37876E-03
3 -5.09983E-02 -6.33872E-02
4 -4.13041E-02 -2.22165E-01
5 -2.04029E-01 5.36386E-03
6 5.17301E-02 -2.00874E-01
7 -6.22429E-02 -6.28153E-02
8 4.18077E-02 -1.98838E-01
9 6.11654E-02 -3.95046E-01
10 -2.55700E-01 -3.81417E-01
11 -8.26849E-02 -8.58337E-02
12 1.24311E-01 -3.76272E-01
13 7.58024E-02 -2.18611E-01
14 2.05511E-01 -5.84841E-01
15 -2.79543E-01 -5.83995E-01
16 -9.49781E-02 -3.90427E-01
17 2.65639E-01 -5.89806E-01
18 7.77479E-02 -7.65915E-01
19 -2.84102E-01 -7.72990E-01
20 -9.45430E-02 -5.92154E-01
21 3.11218E-01 -8.13117E-01
22 8.88679E-02 -9.14073E-01
23 3.52634E-01 0.00000E+00
24 0.00000E+00 0.00000E+00
End Values
Values
1 -3.7497E+03 -4.5383E+03 -3.8455E+03 -3.8291E+02
2 -2.6791E+03 -3.5271E+03 -2.8622E+03 -2.1921E+02
3 -5.4219E+02 -7.2587E+02 -6.0200E+02 -8.0978E+01
4 -4.7399E+02 -7.9289E+02 -5.8969E+02 -1.5173E+02
5 -1.5731E+03 -2.3198E+03 -1.7740E+03 -1.7800E+02
6 5.4963E+02 7.2591E+02 6.0367E+02 -8.0886E+01
7 -5.1100E+02 -9.0246E+02 -6.3556E+02 -2.6520E+02
8 5.0052E+02 7.9972E+02 6.0133E+02 -1.4950E+02
9 5.5367E+02 8.9471E+02 6.4812E+02 -2.5078E+02
10 -8.8679E+02 -1.4262E+03 -1.0346E+03 -2.1365E+02
11 -3.8126E+02 -6.8581E+02 -4.7521E+02 -2.9504E+02
12 3.7568E+03 4.5443E+03 3.8514E+03 -3.8187E+02
13 2.7200E+03 3.5675E+03 2.8990E+03 -2.1228E+02
14 3.0153E+02 5.4410E+02 3.7291E+02 -2.6181E+02
15 1.7422E+03 2.5060E+03 1.9354E+03 -1.4588E+02
16 -5.0763E+02 -7.1711E+02 -5.1710E+02 -2.4051E+02
17 -5.2629E+02 -5.5236E+02 -4.7050E+02 -2.9387E+02
18 1.2653E+03 1.8995E+03 1.4180E+03 -1.2637E+02
19 -3.5150E+02 -1.4331E+01 -1.7459E+02 -2.6353E+02
20 -4.5612E+02 -4.2202E+02 -3.2688E+02 -2.2926E+02
21 -9.4655E+02 -7.0614E+02 -7.1361E+02 -2.5102E+02
22 4.6302E+02 1.0584E+03 6.6611E+02 -2.0880E+02
23 -2.0642E+03 -1.4420E+03 -1.5968E+03 -2.2488E+02
24 -2.2253E+03 -1.3626E+03 -1.6553E+03 -2.8249E+02
End Values
Values
1 5.8869E-03 -3.1978E-02 0.0000E+00 -1.1281E-02
2 6.2052E-03 -2.7215E-02 0.0000E+00 -8.8700E-03
3 3.0106E-03 -1.5064E-02 0.0000E+00 -3.9923E-03
4 3.2656E-03 -1.4180E-02 0.0000E+00 -6.4256E-03
5 5.5491E-03 -1.8738E-02 0.0000E+00 -7.3503E-03
6 -2.8259E-03 3.9988E-03 0.0000E+00 -2.2164E-03
7 3.2406E-03 -1.1490E-02 0.0000E+00 -1.0150E-02
8 -2.8179E-03 3.6663E-03 0.0000E+00 -5.3551E-03
9 -2.2190E-03 2.6020E-03 0.0000E+00 -9.0774E-03
10 2.8193E-03 -1.1079E-02 0.0000E+00 -8.8845E-03
11 1.4841E-03 -7.3988E-03 0.0000E+00 -1.2448E-02
12 -5.7863E-03 6.1481E-03 0.0000E+00 -7.7290E-03
13 -5.9620E-03 8.4785E-03 0.0000E+00 -6.7290E-03
14 -1.4395E-03 1.0919E-03 0.0000E+00 -9.9442E-03
15 -5.3702E-03 9.4462E-03 0.0000E+00 -5.2050E-03
16 -2.7814E-04 -4.1510E-03 0.0000E+00 -6.9459E-03
17 -2.8668E-03 -2.6248E-03 0.0000E+00 -1.0587E-02
18 -3.0280E-03 5.9028E-03 0.0000E+00 -3.8761E-03
19 -9.0999E-03 1.8414E-03 0.0000E+00 -8.9248E-03
20 -1.6204E-03 -1.1679E-03 0.0000E+00 -4.3643E-03
21 -5.7414E-03 -1.3508E-04 0.0000E+00 -7.7176E-03
22 -1.2744E-02 4.7814E-03 0.0000E+00 -3.6221E-03
23 -1.6949E-02 3.3692E-03 0.0000E+00 -7.6220E-03
24 -2.4036E-02 5.8408E-03 0.0000E+00 -4.1732E-03
End Values
Values
1 -2.275E+02 -3.111E+02 -2.050E+02 -2.376E+02
-8.701E+01 -8.385E+01 -6.816E+01 -2.562E+02
-4.023E+02 -2.869E+02 -2.700E+02 -2.404E+02
-5.583E+02 -5.122E+02 -3.934E+02 -2.221E+02
2 -4.794E+02 -9.252E+02 -6.197E+02 -2.468E+02
-1.253E+02 -4.691E+02 -2.629E+02 -2.936E+02
-5.637E+02 -8.428E+02 -6.134E+02 -2.800E+02
-9.144E+02 -1.307E+03 -9.654E+02 -2.281E+02
3 -1.300E+03 -1.994E+03 -1.495E+03 -2.264E+02
-2.933E+02 -8.335E+02 -5.070E+02 -2.739E+02
-5.285E+02 -1.086E+03 -7.161E+02 -1.993E+02
-1.542E+03 -2.239E+03 -1.705E+03 -1.466E+02
4 -2.371E+03 -3.224E+03 -2.572E+03 -2.418E+02
-4.616E+02 -1.066E+03 -6.929E+02 -2.862E+02
-4.965E+02 -1.173E+03 -7.465E+02 -1.317E+02
-2.427E+03 -3.309E+03 -2.626E+03 -9.829E+01
5 -4.796E+03 -5.678E+03 -4.866E+03 -4.377E+02
-4.858E+02 -7.541E+02 -5.684E+02 -4.642E+02
2.148E+02 -3.302E+02 -5.057E+01 -1.759E+02
-4.171E+03 -5.197E+03 -4.330E+03 -1.528E+02
6 -6.627E+02 -4.410E+02 -4.823E+02 -2.975E+02
-3.010E+02 -4.841E+01 -1.570E+02 -3.589E+02
-1.477E+03 -1.022E+03 -1.127E+03 -3.136E+02
-1.857E+03 -1.406E+03 -1.444E+03 -2.320E+02
7 -3.336E+02 -4.802E+02 -3.652E+02 -3.688E+02
1.109E+02 6.803E+01 8.067E+01 -3.914E+02
-2.676E+02 -2.412E+02 -2.278E+02 -3.695E+02
-7.118E+02 -7.937E+02 -6.698E+02 -3.479E+02
8 -5.469E+02 -7.329E+02 -5.761E+02 -3.740E+02
5.530E+02 6.124E+02 5.229E+02 -3.739E+02
6.613E+02 7.095E+02 6.003E+02 -3.184E+02
-4.244E+02 -6.670E+02 -4.818E+02 -3.122E+02
9 -6.184E+02 -7.883E+02 -6.286E+02 -3.518E+02
6.385E+02 7.696E+02 6.281E+02 -3.513E+02
6.788E+02 8.382E+02 6.522E+02 -2.826E+02
-5.485E+02 -7.794E+02 -5.742E+02 -2.789E+02
10 2.856E+02 4.195E+02 2.832E+02 2.467E+02
-2.831E+02 -4.252E+02 -2.855E+02 2.470E+02
-2.307E+02 -4.638E+02 -2.459E+02 1.929E+02
2.846E+02 4.883E+02 2.687E+02 1.957E+02
11 -4.749E+02 6.877E+01 -1.794E+02 -2.001E+02
5.751E+02 1.121E+03 7.791E+02 -4.164E+02
-2.699E+03 -1.739E+03 -2.053E+03 -3.114E+02
-3.725E+03 -2.826E+03 -3.002E+03 -6.279E+01
12 -1.336E+02 2.155E+02 3.557E+01 -2.569E+02
1.259E+03 1.871E+03 1.396E+03 -1.635E+02
1.646E+03 2.244E+03 1.710E+03 -1.761E+01
2.169E+02 6.389E+02 3.354E+02 -1.252E+02
13 1.895E+02 7.207E+02 4.063E+02 -2.443E+02
1.664E+03 2.401E+03 1.847E+03 -1.888E+02
1.838E+03 2.587E+03 1.999E+03 -6.296E+01
3.410E+02 9.311E+02 5.551E+02 -1.089E+02
14 4.442E+02 1.041E+03 6.724E+02 -2.800E+02
2.451E+03 3.308E+03 2.646E+03 -2.304E+02
2.544E+03 3.425E+03 2.732E+03 -7.794E+01
5.135E+02 1.183E+03 7.560E+02 -1.131E+02
15 4.825E+02 7.485E+02 5.643E+02 -4.641E+02
4.802E+03 5.684E+03 4.872E+03 -4.366E+02
4.191E+03 5.214E+03 4.347E+03 -1.508E+02
-2.049E+02 3.370E+02 5.784E+01 -1.755E+02
End Values
Values
1 -2.485E-04 -1.168E-03 0.000E+00 -5.229E-03
-2.485E-04 -2.068E-04 0.000E+00 -6.754E-03
-1.620E-03 -2.068E-04 0.000E+00 -5.889E-03
-1.620E-03 -1.168E-03 0.000E+00 -4.364E-03
2 3.278E-03 -7.134E-03 0.000E+00 -1.153E-02
3.278E-03 -4.911E-03 0.000E+00 -1.399E-02
1.064E-03 -4.911E-03 0.000E+00 -1.199E-02
1.064E-03 -7.134E-03 0.000E+00 -9.528E-03
3 5.902E-03 -1.502E-02 0.000E+00 -1.365E-02
5.902E-03 -9.014E-03 0.000E+00 -1.513E-02
4.575E-03 -9.014E-03 0.000E+00 -9.716E-03
4.575E-03 -1.502E-02 0.000E+00 -8.242E-03
4 6.896E-03 -2.245E-02 0.000E+00 -1.665E-02
6.896E-03 -1.113E-02 0.000E+00 -1.707E-02
6.524E-03 -1.113E-02 0.000E+00 -6.873E-03
6.524E-03 -2.245E-02 0.000E+00 -6.459E-03
5 2.759E-03 -3.198E-02 0.000E+00 -3.448E-02
2.759E-03 -6.203E-03 0.000E+00 -3.100E-02
5.887E-03 -6.203E-03 0.000E+00 -7.805E-03
5.887E-03 -3.198E-02 0.000E+00 -1.128E-02
6 -3.919E-03 8.977E-04 0.000E+00 -1.292E-02
-3.919E-03 2.954E-03 0.000E+00 -1.953E-02
-9.862E-03 2.954E-03 0.000E+00 -1.767E-02
-9.862E-03 8.977E-04 0.000E+00 -1.107E-02
7 8.490E-04 -3.095E-03 0.000E+00 -1.985E-02
8.490E-04 -3.545E-04 0.000E+00 -2.196E-02
-1.049E-03 -3.545E-04 0.000E+00 -1.949E-02
-1.049E-03 -3.095E-03 0.000E+00 -1.738E-02
8 8.079E-04 -4.343E-03 0.000E+00 -2.072E-02
8.079E-04 2.408E-03 0.000E+00 -2.012E-02
1.346E-03 2.408E-03 0.000E+00 -1.404E-02
1.346E-03 -4.343E-03 0.000E+00 -1.464E-02
9 2.644E-04 -4.141E-03 0.000E+00 -1.824E-02
2.644E-04 3.614E-03 0.000E+00 -1.796E-02
5.179E-04 3.614E-03 0.000E+00 -1.098E-02
5.179E-04 -4.141E-03 0.000E+00 -1.126E-02
10 3.273E-05 1.850E-03 0.000E+00 6.694E-03
3.273E-05 -1.926E-03 0.000E+00 6.807E-03
1.344E-04 -1.926E-03 0.000E+00 3.409E-03
1.344E-04 1.850E-03 0.000E+00 3.296E-03
11 -6.956E-03 5.841E-03 0.000E+00 -9.421E-03
-6.956E-03 1.167E-02 0.000E+00 -2.840E-02
-2.404E-02 1.167E-02 0.000E+00 -2.315E-02
-2.404E-02 5.841E-03 0.000E+00 -4.173E-03
12 -3.498E-03 3.722E-03 0.000E+00 -1.063E-02
-3.498E-03 1.212E-02 0.000E+00 -8.356E-03
-1.453E-03 1.212E-02 0.000E+00 -7.987E-04
-1.453E-03 3.722E-03 0.000E+00 -3.071E-03
13 -5.576E-03 8.083E-03 0.000E+00 -1.256E-02
-5.576E-03 1.684E-02 0.000E+00 -1.148E-02
-4.603E-03 1.684E-02 0.000E+00 -3.600E-03
-4.603E-03 8.083E-03 0.000E+00 -4.681E-03
14 -6.700E-03 1.081E-02 0.000E+00 -1.644E-02
-6.700E-03 2.271E-02 0.000E+00 -1.582E-02
-6.138E-03 2.271E-02 0.000E+00 -5.104E-03
-6.138E-03 1.081E-02 0.000E+00 -5.729E-03
15 -2.728E-03 6.148E-03 0.000E+00 -3.098E-02
-2.728E-03 3.198E-02 0.000E+00 -3.438E-02
-5.786E-03 3.198E-02 0.000E+00 -1.113E-02
-5.786E-03 6.148E-03 0.000E+00 -7.729E-03
End Values
Values
1 1.5183E-02
2 1.0000E+00
3 -3.1508E-03
4 4.0793E-03
5 -9.2847E-04
6 -1.2617E-02
7 2.5151E-02
8 1.0000E+00
9 -1.0517E-02
10 1.8735E-02
11 -8.2178E-03
12 -1.4486E-02
13 2.0264E-02
14 1.0000E+00
15 -1.2081E-02
End Values
