[GiDlist] More about visualization in 3D
Hello again
I have tried to separate my volumes in layers and then I get different sets
when switching into post process mode. But this only works when there is no
flavi.res file present. If I have run an analysis and generated a flavia.res
file, I only get one volume set when post processing. What is wrong? There
is an .msh file. Is this file used by GID? When I try to open it in the post
processor I get the error message:” Too few parameters: in this line: 7 -
Reading Mesh.”
/bf
Billy Fälth
Clay Technology AB
Ideon Research Center
S 223 70 Lund, SWEDEN
Tel +46 46 286 25 81
Fax +46 46 13 42 30
www.claytech.se http://www.claytech.se/
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040426/4282e4af/attachment.htm
Your analysis must not write the *.msh file, if not strictly necessary
(only is necessary, for example, if the postprocess mesh must be different of the preprocess one)
If exists this postprocess *.flavia.msh file, then it’s readed instead the preprocess mesh, and this is probably the cause of the error message
Sent: Monday, April 26, 2004 3:02 PM
Subject: [GiDlist] More about visualization in 3D
Hello again
I have tried to separate my volumes in layers and then I get different sets when switching into post process mode. But this only works when there is no flavi.res file present. If I have run an analysis and generated a flavia.res file, I only get one volume set when post processing. What is wrong? There is an .msh file. Is this file used by GID? When I try to open it in the post processor I get the error message:" Too few parameters: in this line: 7 - Reading Mesh."
/bf
Billy Fälth
Clay Technology AB
Fax +46 46 13 42 30
www.claytech.se
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040426/4595a871/attachment.htm
