[GiDlist] More about .... I have applied boundary conditions
Hi Escolano,
I am going better explain my problem below.
I work with galerkin discontinuous and I can to apply different
polynomial order over different elements.
Thus I want to apply over different surfaces different interpolations
and
I d’like to obtain the following output:
APPROXIMATIONS
[number_of_approximation]
[approximation_id] type_of_interpolation (e.g. Lagrange ou Legendre)
[polynomial_order] [integration_order]
ELEMENT
[number_of_element]
[element_id] [approximation_id] [material_id] [node_1] [node_2] …
[node_(nno_by_element)]
However I not access the fields of the approximations applied as
“conditions”, but only as “material”.
How I can to access the fields the questions applied over surfaces as
“conditions”?
My thnaks,
Geraldo Belmonte
Em 2012-10-02 07:00, gidlist-request at listas.cimne.upc.edu escreveu:
Today’s Topics:
1. I have applied boundary conditions over differents contour
lines and I want to access theirs fields. (geraldos)
2. Re: I have applied boundary conditions over differents
contour lines and I want to access theirs fields. (Enrique
Escolano)
Message: 1
Date: Mon, 01 Oct 2012 11:03:44 -0300
Subject: [GiDlist] I have applied boundary conditions over differents
Message-ID: f3961128a11fbd8ad9f8009af267e21e at lncc.br
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Everybody,
I am going to customize my problem type for to analyse, by finite
element methods, a bi-dimensional potential problem.
By *.cnd and *.bas files I created a boundary conditions over lines
called “Prescribed_potential” and I want to access the fields of the
conditions
into of the *.bas file by command *tcl(GiD_Info conditions
prescribed_potential geometry).
How can I to do?
My thanks,
Geraldo Belmonte
Message: 2
Date: Mon, 1 Oct 2012 16:55:53 +0200
Subject: Re: [GiDlist] I have applied boundary conditions over
differents contour lines and I want to access theirs fields.
Message-ID: 2AF6264253074160BF328E3AD42C1FA9 at mediador
Content-Type: text/plain; format=flowed; charset=“iso-8859-1”;
reply-type=original
In the .bas file in general you must only use *tcl commands if it not
possible do what you want with .bas standard commands
(then with Tcl is possible do much more sophisticated thinks, but
probably
less efficiently for big meshes)
typically to access to the fields of the condition applied to nodes
or
elements you do something like
*set cond Prescribed_potential *nodes
*loop nodes *onlyincond
*nodesnum *cond(your_question)
*end nodes
I have assumed that your condition was defined ‘over nodes’, then in
next
loop you will iterate on the nodes with the related condition applied
over
them,
and with *cond you can have the value of the field you want.
it is recommended to use the name of the question, but it is also
possible
to use its numeric index 1, 2, …
(it is better to be maintained, e.g. if in the future you add new
fields to
your condition definition)
Sent: Monday, October 01, 2012 4:03 PM
Hi Everybody,
the
conditions
How can I to do?
My thanks,
Geraldo Belmonte
End of GiDlist Digest, Vol 27, Issue 2
Read again my previous answer, I think that it wa exactly what you are
asking:
first use *set cond … to specify the current condition, and then inside a
loop over nodes/elems you can ask for *cond(fieldname)
e.g.
file .cnd:
CONDITION: Approximation
CONDTYPE: over surfaces
QUESTION: Id
VALUE: 0
END CONDITION
file .bas:
*set cond Approximation *elems
*loop elems *onlyincond
*elemsnum *cond(Id) *elemsmat *elemsconec
*end elems
Sent: Tuesday, October 02, 2012 9:46 PM
Subject: [GiDlist] More about … I have applied boundary conditions over
Hi Escolano,
and
APPROXIMATIONS
ELEMENT
[number_of_element]
[node(nno_by_element)]_
“conditions”?
My thnaks,
Geraldo Belmonte
Today’s Topics:
Escolano)
Message: 1
Hi Everybody,
conditions
How can I to do?
My thanks,
Geraldo Belmonte
Message: 2
reply-type=original
probably
or
*end nodes
next
over
them,
possible
fields to
Hi Everybody,
the
conditions
How can I to do?
My thanks,
Geraldo Belmonte
Dear Sir or Madam,
I tried to create a hexaedron volume mesh with gid and had the error :This volume cannot be structured or semistructured because it is not a prismatic volume. But I don’t know why I get this error. I looked at your example library and found the cajon3D there it is possible and the error doesn’t occur. If I by myself construct a problem similar to that one I get again the upper mentioned error message. Now I wanted to ask you whether there is a tutorial which explains how to construct a cajon like that one, so that I can see why in your example there is no such an error message but in mine there is.
Thank you for your efforts
Yours sincerely
Schröder, Bettina
Universität Kassel, FB 14
Fachgebiet Baumechanik / Baudynamik
Mönchebergstraße 7 - Raum 1309
34109 Kassel
Tel. : 0561/804-2698
Fax : 0561/804-3631
Mail : schroederbettina at uni-kassel.de
Web: www.uni-kassel.de/fb14/mechanics
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20121017/8113e9c6/attachment.htm
Dear Bettina,
Could you please send me the model (it is not needed to send it to the
gidlist, you can send it to my particular e-mail: abelcs at cimne.upc.edu), so
as I can check it?
ABEL
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Bettina Schröder
Enviado el: miércoles, 17 de octubre de 2012 12:25
Asunto: [GiDlist] Prismatic volumes
Dear Sir or Madam,
there is.
Yours sincerely
Schröder, Bettina
34109 Kassel
Fax : 0561/804-3631
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20121017/66c12aec/attachment-0001.htm
