[GiDlist] Meshing volumes with curved surfaces
I am trying to create a mesh for a volume with a curved surface. I am
having the following geometry which I created via rotating 3-point arc by
180 deg (so basically I am having 1 complete cylinder + a spherical cap
which is a small part of a sphere + rest of the body)
[image: Inline image 1]
I created this geometry by rotating the following by 180 deg about its axis-
[image: Inline image 2]
But GID fails to create a mesh, displaying an error saying faces intersect
as shown below (which I don’t think they do)
[image: Inline image 3]
Is there a way to get around this to mesh curved volumes in GID? Basically
my goal is to represent a curved crack front which I am representing via
the spherical cap.
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/84fd19ce/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/84fd19ce/attachment-0003.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/84fd19ce/attachment-0004.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141105/84fd19ce/attachment-0005.png
Do we have a control over the orientation of tetrahedral mesh elements
created by GID. As I see, GID creates a specific orientation of the
tetrahedral elements by default. ( Referring to structured mesh only)
For example, GID creates the following mesh when I mesh it with tetrahedral
elements.
As we can see, the orientation of elements changes around the mid-plane of
the geometry. Is there a way to change this orientation and have a more
consistent one like in the figure below-
There is one other ‘setting’ under preferences of structured mesher in GID
which doesn’t help either.
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/0a624810/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/0a624810/attachment-0002.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/0a624810/attachment-0003.png
It is not possible to control the ‘splitting diagonal’ of structured triangles or tetrahedral.
The only think that you can do is to set the flag ‘Symmetrical structured’ for Tetrahedra (in meshing preferences), then an extra node is create in the center of the ‘structured box’ and then the mesh become more symmetrical.
E.g. for example, in case of triangles without and with symmetrical flag:
Enviado el: viernes, 7 de noviembre de 2014 9:01
Asunto: [GiDlist] Specifying mesh orientation in GID
Do we have a control over the orientation of tetrahedral mesh elements created by GID. As I see, GID creates a specific orientation of the tetrahedral elements by default. ( Referring to structured mesh only)
For example, GID creates the following mesh when I mesh it with tetrahedral elements.
Inline image 1
As we can see, the orientation of elements changes around the mid-plane of the geometry. Is there a way to change this orientation and have a more consistent one like in the figure below-
Inline image 2
There is one other ‘setting’ under preferences of structured mesher in GID which doesn’t help either.
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/097e8283/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/097e8283/attachment-0004.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/097e8283/attachment-0005.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/097e8283/attachment-0006.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/097e8283/attachment-0007.jpeg
Thank you for the information. I wouldn’t need an extra node.
I was just wondering why GID prefers one diagonal over the other for some
element and the other oriented diagonal for some other element, is this
rule arbitrary or is there a
built in predictive algorithm?
Thanks!
symmetrical.
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *amit Dhankhar
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/b99c9faf/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/b99c9faf/attachment-0004.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/b99c9faf/attachment-0005.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/b99c9faf/attachment-0006.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/b99c9faf/attachment-0007.jpg
It is based in the nodes numbering in the moment of the mesh generation, so the user has no control on it.
ABEL
Dr. Abel Coll Sans
Enviado el: viernes, 07 de noviembre de 2014 10:30
Asunto: Re: [GiDlist] Specifying mesh orientation in GID
I was just wondering why GID prefers one diagonal over the other for some element and the other oriented diagonal for some other element, is this rule arbitrary or is there a
Thanks!
Inline image 1
Inline image 2
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/01591cbb/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/01591cbb/attachment-0004.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/01591cbb/attachment-0005.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/01591cbb/attachment-0006.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/01591cbb/attachment-0007.jpeg
Unfortunatelly you cannot control the orientation of the structured tetras. The only option is to set the ‘Symetrical structured’ option in the Preferences-Meshing window, which will lead to a different configuration of tetras which is symmetrical. In the other hand, it produces a higher number of elements.
ABEL
Dr. Abel Coll Sans
Enviado el: viernes, 07 de noviembre de 2014 9:01
Inline image 1
Inline image 2
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/6eba6efd/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/6eba6efd/attachment-0002.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141107/6eba6efd/attachment-0003.jpeg
