[GiDlist] Meshing of contact volume elements
Dear GID developers,
I would like to ask about how to mesh a tube filled with a certain material and there is
a contact/ interface between them.
For 1/8 of the section, I can mesh the material inside with hexahedral elements easily.
Also, the thin tube can be meshed with hexahedral elements properly. However, when
I put a contact volume between them, I could not get the right mesh for the tube
(the previous mesh changed irregularly - see a figure). The input file and the figure are
attached in this email.
I am looking forward your explanation for this problem.
Sincerely,
Muslikh
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031114/9d7c35db/attachment.htm
Desc: Try.gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031114/9d7c35db/attachment.bin
Yes, this is a known bug using contacts.
To temporary avoid the problem in your model, you can set the same normal sense for the surfaces linked by the contact (swap the normal of the surface 6 and 9 to be the same sense as the surface 4).
Sent: Friday, November 14, 2003 7:17 AM
Subject: [GiDlist] Meshing of contact volume elements
Sincerely,
Muslikh
Do you Yahoo!?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031117/e3b6bc1f/attachment.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031117/e3b6bc1f/attachment.png
Dear Gid team,
I want to get rig off the box appearing at the end of the calculate
action which informs me that the calculation which was started at xxx
date and time was ended. I don’t want to click on the ok button or
postprocess button each time. Could you help me with this problem.
Thanks ahead.
Can use a trick to disable the window message:
