I rebuild your shape avoiding the parametrization problems of your model and it could be meshed without problems.
You have created the extruded surface rotating a curve 180º that cross the rotation axis,
I created the same shape, but dividing the curve and deleting half part, and rotating 360º.
If fact it will be less problematic creating two surfaces not closed (with a rotation of 180º and multiple copies=2 in the copy window)
And the lower plane will be less problematic creating a planar surface by its boundary, avoiding the creation by rotation
(the poles of a surface of rotation are problematic, because this degenerated points have zero derivative in one parametric direction)
Enviado el: lunes, 17 de noviembre de 2014 18:52
Asunto: [GiDlist] Fwd: Meshing curved volumes
Hi Enrique,
Would you suggest trying out some other version for GID for the meshing issue of the curved geometry I created?
Thanks!
On Thu, Nov 13, 2014 at 10:40 AM, amit Dhankhar amit12kd at gmail.com wrote:
I tried the repair geometry option which just says “everything was ok” but fails to mesh. I created my volume by rotating a 2-d curved surface about its own axis. (which retains the original 2-d surface and creates extra points and lines which I have to collapse later)
I have attached a zip file containing the simple model - “nov13_curvedvol_original.gid” - volume created by the rotation which GID fails to mesh. Could you tell me what else could be wrong in this one? I am running 12.1.1d version of GID.
In another attempt, “nov13_curvedvol_mod.gid” - I wanted to get rid of extra surfaces, lines and points so I deleted the original 2-d surface and the extra lines and tried reconstructing the volume which gives out an error. This file just has the curved surface and it’s base surface (which ideally should represent a bounded domain)
On Mon, Nov 10, 2014 at 12:26 PM, Enrique Escolano escolano at cimne.upc.edu wrote:
Try to fix some geometrical problem with Utilities-Repair
Try to set all default meshing option. In utilities preferences meshing press the Reset button
If it continue without mesh trying a reasonable mesh size then attach a zip with your model to have a look
Enviado el: viernes, 7 de noviembre de 2014 20:32
Asunto: [GiDlist] Meshing curved volumes
I am trying to mesh a simple geometry of the form of a spherical cap ( created by rotating an arc about its axis) but GID shows up some meshing error. Creating spherical caps from boolean operations don’t work either.
Here’s how my geometry looks like-
Inline image 1
It was created by rotating this surface around it own axis (bounded by an arc and a line)-
Inline image 2
As we can see, it shows up error saying ‘two faces intersect’. Is there any other way to mesh such volumes?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0002.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0003.jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141117/a50bbea9/attachment-0001.obj
