Thanks Enrique!
Now I have got another issue. Till yesterday, my GiD software was working perfectly but now it is giving me problem both in preprocess and postprocess. I have attached the screenshots of my preprocess window and the postprocess window. Moreover, I have also attached my project folder as well. The preprocess is not showing the geometry as it was showing before and postprocess is not showing any result. Can we see what is the problem? Is the problem with project folder or with the software itself?
Best Regards,
Abdul Maalik
PhD Student
ElectroScience Laboratory
Department of Electrial and Computer Engineering
Ohio State University
Columbus, OH 43212
USA
From: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Enrique Escolano
Sent: Friday, August 01, 2014 9:32 AM
Subject: Re: [GiDlist] Viewing results in GiD Postprocess
Instead of create graphs from menus, it is more comfortable to create them from the Graphs window (Window-View graphs…)
[cid:image001.jpg at 01CFADA8.63DD9250]
And to select the start and end points, if the center is an existing node, then you can simply pick it (or enter its id number).
If the mouse cursor is a “+” then GiD is expecting a new coordinate x,y,z but you can swap to pick an existing point with Ctrl-a (or click the contextual menu and select “Join”)
If the center is not a node you must calculate its coordinates and enter the x,y,z
And for the end point you can calculate also its x,y,z or you can enter the coordinates relative to the previous point (the center) with this syntax starting by @
@x,y
Or with polar coordinates:
@radius,angle
I think that the polar option is what you want. Angle is in degrees, starting from x axe counter-clockwise
e.g. to go 0.2 units in a direction of 45 degrees enter
@0.2,45
De: gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Maalik, Abdul
Enviado el: viernes, 1 de agosto de 2014 2:03
Para: gidlist at listas.cimne.upc.edumailto:gidlist at listas.cimne.upc.edu
Asunto: [GiDlist] Viewing results in GiD Postprocess
I have a 2D plot of current density of a circular plate. Now I want to plot the variation of current along a radial line (rho) at some given angle (phi).I know that I can go to
View results/Graphs/Line graph. Now I have two questions regarding this.
i) How can I specify the start and end point of the radial line ? (starting point should be center of circular plate and end point should be on the circumference of the plate)
ii) How can I specify the angle (with respect to horizontal axis) at which the radial line is to be drawn?
Best Regards,
Abdul Maalik
PhD Student
Columbus, OH 43212
USA
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140801/6fb7e70b/attachment-0001.htm
Type: image/jpeg
Desc: image001.jpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140801/6fb7e70b/attachment-0001.jpg
Desc: CenterFedRef10G.gid.rar
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140801/6fb7e70b/attachment-0001.obj
Name: preprocess problem.png
Type: image/png
Desc: preprocess problem.png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140801/6fb7e70b/attachment-0002.png
Name: postprocess problem.png
Type: image/png
Desc: postprocess problem.png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140801/6fb7e70b/attachment-0003.png
