[GiDlist] issues when importing binary STL files in GiD
Dear All,
I have problems when importing STL binary files in GiD (version
11.1.5d), there is apparently a memory overhead during the loading
process. Files were created adopting the /stlwrite/ Matlab function (see
attachment). The ascii STL format on the other hand gives no problems.
Attached please find two .stl files so you can give it a try.
Here’s a link to a 100mb binary stl file (which gives problems when
loaded in GiD: https://dl.dropboxusercontent.com/u/10874082/test_big.stl
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/a9648eff/attachment-0001.htm
Type: text/x-objcsrc
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/a9648eff/attachment-0003.bin
Type: application/sla
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/a9648eff/attachment-0004.bin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131016/a9648eff/attachment-0005.bin
Hello Marco,
I have tested all your examples and GiD is able to read them without
problems.
I tried with the current versions:
  •      Win x32 official 11.0.5 version
  •      Win x32 developer 11.1.6d version
The big Stl binary model (about 2 millions of triangles and 1 million of
nodes) is imported in about 15 seconds and the GiD process spend about 250
MB more than before read it.
What is the GiD version that you are using?
Maybe the problem only happen in some old GiD version, or in another
platform.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Marco Giometto |
EPFL
Enviado el: miércoles, 16 de octubre de 2013 23:19
Asunto: [GiDlist] issues when importing binary STL files in GiD
Dear All,
I have problems when importing STL binary files in GiD (version 11.1.5d),
there is apparently a memory overhead during the loading process. Files were
created adopting the stlwrite Matlab function (see attachment). The ascii
Here’s a link to a 100mb binary stl file (which gives problems when loaded
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/90156c97/attachment.htm
Hello Enrique,
I’m running GiD on Ubuntu 12.04 64bit, sorry for not mentioning that
before. Could you give it a check?
Marco
On 10/17/2013 12:03 PM, Enrique Escolano wrote:
Hello Marco,
problems.
-Win x32 official 11.0.5 version
-Win x32 developer 11.1.6d version
of nodes) is imported in about 15 seconds and the GiD process spend
about 250 MB more than before read it.
platform.
De:gidlist-bounces at listas.cimne.upc.edu
[mailto:gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Marco
Giometto | EPFL
Dear All,
(see attachment). The ascii STL format on the other hand gives no
problems.
_loaded in GiD: https://dl.dropboxusercontent.com/u/10874082/test_big.stl_
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/17b68eb2/attachment.htm
And which GiD version? (see Help-About)
EPFL
Enviado el: jueves, 17 de octubre de 2013 13:04
Asunto: Re: [GiDlist] issues when importing binary STL files in GiD
Hello Enrique,
I’m running GiD on Ubuntu 12.04 64bit, sorry for not mentioning that before.
Marco
Hello Marco,
problems.
platform.
EPFL
Dear All,
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/e3297e25/attachment-0001.htm
both 11.1.2d and 11.1.5d are giving issues when importing.
Giometto | EPFL
Hello Enrique,
Marco
Hello Marco,
without problems.
million of nodes) is imported in about 15 seconds and the GiD
process spend about 250 MB more than before read it.
another platform.
Giometto | EPFL
mailto:gidlist at listas.cimne.upc.edu
Dear All,
function (see attachment). The ascii STL format on the other hand
gives no problems.
when loaded in GiD:
_https://dl.dropboxusercontent.com/u/10874082/test_big.stl_
Marco Giometto
GiDlist at listas.cimne.upc.edu mailto:GiDlist at listas.cimne.upc.edu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/5394777d/attachment.htm
The problem with the binary STL on Linux64 was caused by a bug in the STL
binary reading code. Now it’s corrected for the next version of GiD.
With the correction, both models can be read.
Miguel Pasenau
EPFL
Enviado el: jueves, 17 de octubre de 2013 16:22
EPFL
Hello Enrique,
Marco
Hello Marco,
problems.
platform.
EPFL
Dear All,
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/494b9725/attachment-0001.htm
hola necesito ayuda para mallar esta pieza pero también las instrucciones sobre como corregir los errores yo mismo .muchas gracias y espero una respuesta.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML…
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/df63ed0e/attachment-0001.htm
Se ha borrado un mensaje que no est? en formato texto plano…
Nombre : pr.IGS
Tipo : application/iges
Tama?o : 7251506 bytes
Descripci?n: no disponible
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131017/df63ed0e/attachment-0001.bin
