Hello Marco,
You can visualize a result contour fill over isosurfaces like this:
create the isosurfaces ( for instance x-velocity)
as you said select options–isosurfaces–color mode-- contour fill
doing now a contour fill of another result will draw the contour fill of this result over the isosurface too, like this:
here there are three isosurfaces of vorticity at values 0.1, 0.4 and 1 and the contour fill drawn is of the velocity modulus. Also there are two cuts of the volume mesh, one is parallel to the xy plane, and the other one perpendicular to it and near the cylinder, crossing the isosurfaces too.
if you select Options–isosurfaces–Color mode–result color the the isosurfaces will be drawn with the color of the result used to create those isosurfaces, like this:
Here the isosurfaces are blue-green-red corresponding to the isovalues 0.1-0.4-1.0 of vorticity ( result used to create the isosurfaces), and at the same time the contour fill of the velocity modulus is drawn.
Hope it helped,
best regards,
Miguel Pasenau
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Anna Monros
Enviado el: miércoles, 13 de febrero de 2013 12:18
Asunto: Re: [GiDlist] Isosurfaces of different colors on top of a contour plot
Dear Marco,
Yes, but you should follow a last step, after changing the colour mode please select the contour fill result.
If no contour fill is selected the iso surfaces are displayed in monochrome colour.
El martes, 12 de febrero de 2013 19:00:21, Marco Giometto | EPFL escribió:
I’m plotting multiple results through GiD postprocess (see attached
pictures). I managed to get a contour plot along a cut and then I
wanted to plot on top of it 3 iso-surfaces of the x-velocity, giving
to each of the surface the corresponding color in the contour plot,
but didn’t manage to do this last step: the isosurfaces were displayed
all with the same color if I chose Optionsisosurfacescolor mode
contour fill color.
Is there a way to obtain the 3 isosurfaces with different colors, each
corresponding to the given contour value?
Marco Giometto
Anna Monros Bellart
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d’accés, rectificació, cancel•lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130214/125f877d/attachment-0001.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130214/125f877d/attachment-0002.png
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130214/125f877d/attachment-0003.png
