Dear Gid List:
I have just downloaded the gid8.0.1-dyn-64.tar.gz and installed on a
SUSE-9.1 intel em64t machine.
Note, I had to fix permissions on several files to be able to use it as
a normal user.
My question is: can I use gid to output the results of a time series ,
interpolated to a set of spatial points not necesarrily on nodes? Like
the graph point evolution function but with a possibly large set of
points. Or, can the results be directly interpolated from one mesh onto
another? If not can anyone recommend a tool that does something like
that ? Thanks
Robert Atwood
Our company, Compass Ingeniería y Sistemas, has developed a tool for
interpolating data between two meshes. It can work both as a library
for coupling two analysis programs and as a program to transfer calculated
results from one mesh to another. We use it for meshes in the range of the
hundreds to the few million elements.
Up two now we have used it internally and with other partners in several
common projects.
We are considering now to convert into into a product and put it into
the market. Contact us if you are interested in it.
En Wed, 31 May 2006 19:09:54 +0200, Atwood, Robert C
r.atwood at imperial.ac.uk escribió:
Dear Gid List:
a normal user.
that ? Thanks
Robert Atwood
our Institute for Structural Concrete is working with the FE-Programm
Atena now. Since we are using GiD as our standard pre- and
postprocessor, it would be easy for us, if we could use GiD for Atena
as well …
Cervenka consulting offers an interface to create Atena input files
from GiD models, but no options for postprocessing the results. Since
we are using GiD also with other programms, we would like to do the
postprocessing with GiD as well. So we began to write a programm
which transfers the Atena results in GiD flavia.msh and flavia.res
files.
My question: Has somebody already done programming for an Atena-GiD
interface like this or is interested in sharing our programms?
Sören Schwarz
Universität Leipzig
Wirtschaftswissenschaftliche Fakultät
Institut für Massivbau und Baustofftechnologie
Marschnerstrasse 31
04109 Leipzig
Dipl.-Ing. Sören Schwarz
Tel.: 0341/97-33800 (Sekretariat)
Tel.: 0341/97-33813 (Durchwahl)
Fax: 0341/97-33809
e-mail: sschwarz at wifa.uni-leipzig.de
URL: http://www.uni-leipzig.de/massivbau
Mit freundlichen Grüssen
Sören Schwarz
mailto:sschwarz at wifa.uni-leipzig.de
Type: text/x-vcard
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20060602/cb0c4bab/attachment.vcf
as well …
files.
Sören Schwarz
I didn’t hear about anyone who has done some work on Atena-GiD, sorry.
But for writing the postprocessing files ( ‘.post.msh’ and ‘.post.res’) you
can also use the ‘gidpost’ library, which has an interface for fortran too.
You can get it from here:
http://www.gidhome.com/support/gidpost.subst
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Sören Schwarz
Enviado el: viernes, 02 de junio de 2006 15:32
Asunto: [GiDlist] ATENA - GiD Interface
as well …
files.
Sören Schwarz
