Dear GiD team,
I have a problem of GiD crash.
When I try
Files–Import–Insert GiD model
and choose some model then crash.
I am using GiD 11.1.9d 64bit on Windows 8.1 pro 64bit.
Thanks in advance,
HEMMI, Shigeru
Dear GiD team,
When I try
Thanks in advance,
HEMMI, Shigeru
It seems that it crash only when inserting a model in an empty model.
For this case doesn’t has sense to use insert, use the normal open. Insert
model is just interesting to add a model to an existing model.
We will fix it for next GiD 12.0.1 version
Thanks for your information
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de HEMMI, Shigeru
Enviado el: martes, 29 de julio de 2014 23:41
Asunto: [GiDlist] Import-Insert GiD Geometry crashes on Windows 64bit
Dear GiD team,
When I try
Thanks in advance,
HEMMI, Shigeru
Hi all ,
If I want to calculate the integration of a scalar result for multiple
cuts, respectively, what should the code be for a macro? Thank you very
much.
Best,
Long
This email is free from viruses and malware because avast! Antivirus protection is active.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140729/5c33a1e5/attachment.htm
You can do the integral of a scalar along a cut without programming any macro, with the current tools: View Results-Integrate
Do a macro to use this tools for multiple cuts could be difficult because selection cuts is cryptic (you cannot know a priori the name of the cut)
e.g.
GiD_Process Mescape Results Graphs Integrate 3D ThisStep ScalarResult my_name my_component -2147352474
In this case -2147352474 is the ‘cryptic name’ to select my cut!!
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de long
Enviado el: miércoles, 30 de julio de 2014 0:07
Para: GiDlist at listas.cimne.upc.edu
Asunto: [GiDlist] How to use macro in GiD?
Hi all ,
If I want to calculate the integration of a scalar result for multiple cuts, respectively, what should the code be for a macro? Thank you very much.
Best,
Long
This email is free from viruses and malware because avast! Antivirus http://www.avast.com/ protection is active.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140730/5f5263f1/attachment.htm
