I don’t understand exactly your question:
change the element type or size?
If you want to re-mesh a shape defined by a previous mesh, it exists an option, import as a “Surface mesh”
(menu Files-Import-Surface mesh…), the source file must be a GiD ASCII mesh file, or a STL file.
and try to generate a new mesh over this pseudo-surface.
Note: This mesh generation only works for simple cases.
Sent: Tuesday, February 17, 2004 5:38 PM
Subject: [GiDlist] Import GiD Mesh
Hello all,
After importing ‘GiD mesh’ to the preprocess -
can I change the mesh (elements type, size etc.) ?
