hi!!
I have followed the indications that you wrote me, but the results continue being the same ones: Curves of level each five meters but my origin file dxf draws curves each meter. In gid I will create a NUrb-surface with the tool BYlinepoints.
When i import the dxf file in gid appears a window with the following information:
WARNING: Line number 72 has bad definition
and couldn’t be fixed. You should erase it
In your file exist two types of DXF entities: LWPOLYLINE and POLYLINE
But in your sample, the POLYLINE use a internal flag=128, and GiD ignore this entity with this flag
(because a bad interpretation/explanation of the DXF reference format)
The next week a new Beta version of GiD is released, and this version can read this type of entity.
You can also try to change from AutoCAD this flag, or explode polylines.
Note: A surface generated “ByLinePoints” is only a smooted aproximation to the source lines.
Sent: Friday, October 18, 2002 4:18 PM
Subject: [GiDlist] import dxf archive
hi!!
