Hello together,
I need your help for following “plotting”-problem:
Multi-material elements can have more than 1 material. In attached
illustration, a simple model with 3 elements, two materials has been
drawn.
- Left element is filled (100%) with material 1.
- Right element is filled (100%) with material 2.
- Center element is mix-filled: 60% with material 1 and 40% with material 2.
I want to let GiD plot the center element in 2 colors as the
illustration shows. Some idea how to do that? Is it possible at all in
current GiD version (Linux: 7.7.2)?
As for the left and right element I do following:
- I make a range table:
- 0.0 - 1.0 : material 1
- 10.0 - 11.0 : material 2
- if f1 is equal 1.0 then fillingrate f = f1
if f2 is equal 1.0 then fillingrate f = 10.0 + f2
I works well. Unfortunately for the center element does not.
Thank you in advance for any suggestion
Rafael
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051226/88aefdf6/attachment.png
