If you need a program for heat transfer in either solid or fluid dynamics,
you should consider TDYN. If you want more information on TDYN, please contact
me.
If you need a geotechnics solver, with coupled thermal, mechanical and other
effects, I can point you to a group that is marketing one.
El vie, 30 mar 2001, escribiste:
Hi Enrique,
Thanks for your reply about the graphics problem. Nothing worked however but i did not try to disable the graphics card as i would rather not
do this. I will eventually be trying the software on another computer anyway so i guess it’s not too much of a problem. I was also wondering however if
there are any good solvers that have been made compatible with Gid. I want to look at built environment heat and mass transfer but as far as i can tell
none of the solvers on your website do heat and mass transfer. Are there any others out there, preferably of low cost. I understand that any solver can be
used with Gid if you can tell gid the right format to output but I’d take an easier way if there was one.
Ryan
