Each time I call a gidpost funcion I receive a LNK2019 error, for example:
Error 6 error LNK2019: símbolo externo
_GID_OPENPOSTMESHFILE sin resolver al que se hace referencia en la
función _OUTPUT_mp_OUT_GID_DAT output.obj
I had directly gidpost.lib to the project as a source file and I had also
gidpost.lib to “Additional dependencies-Input-Linker-Prperties”. I tried
also to define “Additional Lybraries Directories-General-Linker-
Properties” to define the lib path.
Thank you very much for your help.
Jose.A.Fernandez at cedex.es wrote:
Dear GiD Team,
I want also to transfer my fortran code from compaq Visual fortran
6.6
to Intel IA-32 compiler v.10 (running on Visual Studio 2005) and I
have
the same problem described in previous mails found in the Gidlist
archives. Is this problem solved or is it a trivial mistake from my
Visual Studio project definition?
-I m using gidpost 1.7.
-The linker says that the defined function in the given gidpost.lib
are
could you send us the output messages from the linker?
not founded (even if the library is included in the project).
-I m not able to build gidpost.lib as environment is not defined in
cfortran.h.
Thanks for your help.
Best regards.
José Antonio
GiDlist at gid.cimne.upc.edu
Este mensaje ha sido enviado usando Endymion MailMan.
http://www.endymion.com/products/mailman/
