[GiDlist] 答复: GiDlist Digest, Vol 32, Issue 6
Hi, Mr. Escolano,
Thank you for your answer.
But I am doing the same as you do, you can found the screenshot in
attachment, Press F5 and nothing happened. What’s wrong? Is there any
relationship with Gid license? (I am still using the trial version which can
only support 1000 node mesh.)
Michael Liu
-----邮件原件-----
发件人: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.
cimne.upc.edu] 代表 gidlist-request at listas.cimne.upc.edu
发送时间: 2013年3月21日 19:00
收件人: gidlist at listas.cimne.upc.edu
主题: GiDlist Digest, Vol 32, Issue 6
Today’s Topics:
  1. Why RamDebugger not works? (???)
  2. Re: Why RamDebugger not works? (Enrique Escolano)
Message: 1
Date: Thu, 21 Mar 2013 17:34:19 +0800
Subject: [GiDlist] Why RamDebugger not works?
Message-ID: 000601ce2617$463f9b40$d2bed1c0$@asia
Content-Type: text/plain; charset=“gb2312”
Hello guys,
Gid have Ramdebugger which is said to be able to debugging TCL in Data?
Problem Type ?Debugger.
I tried to use RamDebugger per following course
http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%2
0code.pdf
but nothing happened. The Debugger seems not work? Anybody know the reason.
How can I debug in RamDebugger? I am using Gid 10.0.9
Michael Liu
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/fe4b9d17/
attachment-0001.htm
Message: 2
Date: Thu, 21 Mar 2013 11:31:21 +0100
Subject: Re: [GiDlist] Why RamDebugger not works?
Message-ID: 256EB3F4FA63425195957BEDD23BABF7 at mediador
You must open RamDebugger (e.g. press F12 in GiD or from the
Data-Problemtype-Debugger… menu)
then open the Tcl file you want to debug,
and then press F5 in RamDebugger to start debugging (and you can set
breakpoints F9 to stop the flow and see/change variables)
Sent: Thursday, March 21, 2013 10:34 AM
Hello guys,
Data?Problem Type ?Debugger.
0code.pdf
reason. How can I debug in RamDebugger? I am using Gid 10.0.9
Michael Liu
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/bd76c7cf/
attachment-0001.htm
End of GiDlist Digest, Vol 32, Issue 6
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130322/91a8605b/attachment-0001.png
Hi Michael Liu,
It seams that Ramdebugger its already debugging Find on downright
corner (VCS:debug)
The problem its that you don’t have any breakpoint.
Put a break point with F9 and one of the following options:
  1. press again F5 to let ramdebugger read again and execute
    the file
  2. source the file (on GiD command line write “-np- source
    {D:/GiD 10.0.9/test.tcl}”)
  3. if breakpoint its inside the proc HelloWorld, execute the
    proc (on GiD command line write “-np- HelloWorld”)
Adrià
El 22/03/2013 11:40, 刘力风 escribió:
Hi, Mr. Escolano,
Michael Liu
-----邮件原件-----
Today’s Topics:
Message: 1
Hello guys,
0code.pdf
Michael Liu
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/fe4b9d17/_
attachment-0001.htm
Message: 2
Hello guys,
0code.pdf
Michael Liu
URL:
_http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/bd76c7cf/_
attachment-0001.htm
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130322/40eb8883/attachment.htm
