Hi
I have 2 problems when making “Utilities - List - nodes or elements”:
- it is very slow. When pressing escape it needs about 5 seconds with 600 nodes to have them marked on the screen and to appear the List Entities Window. Until I have the limited evaluation version but what will be with a 100000 nodes-model?!
Is there a way to change this behaviour?
- Making lists, sometimes GiD crashes when releasing the mouse button. How to avoid this? I did already deinstall und reinstall.
Thank You in advance for Your suggestions
Best regards, Johannes Ackva
Ingenieurbüro für Mechanik
Dr.-Ing. Johannes Ackva
Markgrafenstr. 21
D 91717 Wassertrüdingen
The list tool is not designed to list a big amount on entities (maybe can be
enhanced for next versions).
Usually it must be only used to check some entities.
To list all mesh, it’s best for example to export as a “Text data report”
ascii file, and open it with some text editor.
About the crash when select entities: What GiD version do you use? (If you
use a version lower than 7.5.1b, download this last beta version).
If the problem persists with this last beta version, and you can repeat this
problem, please, send us a
brief explanation about how to crash GiD, to solve it.
Sent: Monday, November 15, 2004 8:26 AM
Subject: [GiDlist] Gid7.4.3b with Win 2000: Problems with listing nodes or
elements
Hi
1) it is very slow. When pressing escape it needs about 5 seconds with 600
2) Making lists, sometimes GiD crashes when releasing the mouse button.
Markgrafenstr. 21
You can do it in this way:
define an elemental property, like ‘existence’, on the elements which remain on
every step. So: do not define this results for the elements that are to be
removed, and so, when you do a c.fill. of this results, the elements which do
not have the result will not be drawn.
i send you enclosed an example: excavacion.msh, excavacion.res and a movie
file: excavacion.mpg
Hope it helps,
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de De silva mahinda
Enviado el: martes, 16 de noviembre de 2004 2:52
Asunto: [GiDlist] Is it posible to remove some elements at the post prossesing?
Dear Sir,
I am doing some problems related to excavation. there i have to remove
elements. so i have some problem at the post prossecing. i wants some elements
to be un effective or remove from the post prossesing. and even when i watch
the animation.
let say i have a rectanglular meash with 8 elements. and let say i have 2 load
steps in animation.
i need to remove 2 elements at step 1 and another 2 elements at last load step.
how can i do it only at post processing?
please advice me.
FREE pop-up blocking with the new MSN Toolbar MSN Toolbar
http://g.msn.com/8HMBEN/2755??PS=47575 Get it now!
_______________________________________________ GiDlist mailing list
GiDlist at gid.cimne.upc.es http://gid.cimne.upc.es/mailman/listinfo/gidlist
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041117/32bcb865/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041117/32bcb865/attachment.obj
Type: video/mpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041117/32bcb865/attachment.mpg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20041117/32bcb865/attachment-0001.obj
