Hi Enrique
I know that GiD can generate beam and shell element
but these should be seperated. In my case can GiD
generate the beam and shell? Please look at the
attached file. The model in the attached file is
generated by hand(xxx.msh) and import by GiD mesh
command.
Any technic to have GiD generate it automatically?
I can’t see GiD7.1.7b-win.exe on the CIMNE/GiD
webpage yet. Still only GiD7.1.3b.
Enrique Escolano http://www.gidhome.com escolano at cimne.upc.es CIMNE - Centro Internacional de Métodos Numéricos en Ingeniería C/ Gran Capitán s/n, Modulo C1, Campus Norte UPC, E-08034 Barcelona, Spain tel. +34 93 401 74 03
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
By default, if GiD generate the surface “shell” mesh elements, then not
generate
the line “beam” elements for the contour lines of this surfaces.
To force to generate also this line elements, use the menu:
Meshing-Mesh Criteria-Mesh-Lines
and select the desired lines.
GiD 7.1.7b-win.exe is in the same directory as GiD7.1.3b-win.exe!!
Sent: Thursday, November 28, 2002 5:43 AM
Subject: [GiDlist] Can GiD generate beam-shell element together?
Hi Enrique I know that GiD can generate beam and shell element but these should be seperated. In my case can GiD generate the beam and shell? Please look at the attached file. The model in the attached file is generated by hand(xxx.msh) and import by GiD mesh command. Any technic to have GiD generate it automatically? I can’t see GiD7.1.7b-win.exe on the CIMNE/GiD webpage yet. Still only GiD7.1.3b. Regards. — Enrique Escolano escolano at cimne.upc.es wrote: Dear all. It is available a new GiD beta version 7.1.7b for Windows. To download GiD7.1.7b-win.exe, see the "download beta versions" section of the GiD page
_http://www.gidhome.com/download/do07.subst_ Regards
— Enrique Escolano escolano at cimne.upc.es wrote: 1) By default, if GiD generate the surface “shell” mesh elements, then not generate the line “beam” elements for the contour lines of this surfaces. To force to generate also this line elements, use the menu: Meshing-Mesh Criteria-Mesh-Lines and select the desired lines. 2) GiD 7.1.7b-win.exe is in the same directory as GiD7.1.3b-win.exe!!
Enrique Escolano ----- Original Message ----- From: “VSayako Willy” vilaysako at yahoo.com To: gidlist at gatxan.cimne.upc.es Sent: Thursday, November 28, 2002 5:43 AM Subject: [GiDlist] Can GiD generate beam-shell element together?
Hi Enrique and all GiD team
I would like my fields appear on the windows box
from the LEFT JUSTIFY,original GiD start from Right.
Can we modify those such things in tcl files of GiD?
LEFT JUSTIFY:
XXXXXXXXXXXXXX
XXXXXXXXXX
XXXXXXX
XXXXXXXXXXXX
RIGHT JUSTIFY:
XXXXXXXXXXXXXX
XXXXXXXXXXXXXXXX
XXXXXXXXX
Regards.
Do you Yahoo!?
Dear VSayako, there is no way (except dealing with tcl code) to force
GiD to make a left justify in the data windows. But there is way you can
solve it. Using the field TKWIDGET (now an internal feature)
you can draw the contents of the data windows as you wish. Here is
attached a document on this feature and a sample doing a right justify
of the labels in the problem data window. Hope it helps.
best regards,
Jorge Suit
VSayako Willy wrote:
Hi Enrique and all GiD team I would like my fields appear on the windows box from the LEFT JUSTIFY,original GiD start from Right. Can we modify those such things in tcl files of GiD? LEFT JUSTIFY: XXXXXXXXXXXXXX XXXXXXXXXX XXXXXXX XXXXXXXXXXXX RIGHT JUSTIFY: XXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXX
