[GiDlist] GID version 7. for Sun Solaris
Dear Jorge,
I appreciate informing me when the new beta version correction will be
available.
Sincerely;
Abedzade
Hello:
I have recently downloaded the 7.1.3b version and I noticed something that
could be a problem.
The structure I am dealing with is axiperiodic, but only one cross-section
is modeled. I therefore have a 2D geometry made of 2nd order quads. When
I go to post-processing, I want to re-create a wedge of the 3D structure by
extruding the 2D mesh. This can, theoretically, be done with the
copy/transform function in GiD.
I select rotation, then an angle, and the points that define the
axis. Then, I select Create, and Extrude Surface.
This works OK in 7.1, although the rotation is linearly
interpolated. Therefore, only small rotation angles can be used.
I was hoping that with the new capability in 7.1.3b of curvilinear
representation of quadratic elements, this would have resulted in better
drawings. However, GiD 7.1.3b seems to bomb when I try that type of
post-processing extrusion. Am I doing something wrong?
Thanks.
Philippe
Thanks by notifying this bug, we will correct as soon as possible.
From: “Philippe Bouchilloux” pb at magsoft-flux.com
To: “GiDList” gidlist at gatxan.cimne.upc.es
Sent: Thursday, October 31, 2002 6:21 PM
Subject: [GiDlist] Possible problem with extrusion in post-processing
Hello:
could be a problem.
by
Thanks.
Philippe
yes you’re right, there are transformation/copy problems when the new mesh/set
is created, with cuadratic elements.
but you can still do the transformation without creating it.
extrusions crash . . . for cuadratic elements
wil be fixed for 7.1.4b
Philippe Bouchilloux wrote:
Hello:
could be a problem.
Thanks.
Philippe
