You can restore it back the way Matrin Meiler told you.
¿Only the top menu bar disappeared? If so, you can also restore it back by:
- right click over any icon of the icon bars, the right menu or the command
lines, and a contextual menu will pop up,
- select the option ‘Configure toolbars’ from the menu
- the entry ‘Up menu’ of the listbox refers to the top menu bar
- check the radiobutton option ‘inside’ and the top menu bar should appear.
¿can you tell us how did the menu bar disappear? ¿was it with the latest gid
8.0.2?
thanks
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Martin Meiler
Enviado el: lunes, 31 de julio de 2006 13:51
Asunto: Re: [GiDlist] GID ver. 8 stoped displaying the menu tool bar
there is a directory where all your personal GiD settings are stored. It
can be found at
Windows %APPDATA%\GiD\gid.ini
where %APPDATA% is something like
c:\Documents and Settings\USERNAME\Application Data
or
Linux ~/.gidDefaults
Just rename this file and the menu should reappear.
Martin
Dr. Kobeid wrote:
My GID ver. 8 stoped displaying the menu tool bar (I.e, Files,
Utilities, , etc)
Is there a way to restore it back because I have reinstall the software
and the problem still there, I even installed the older version 7.2 but
still having same problem.
thanks,
K
/ // /// Friedrich Alexander Universität Erlangen
_/ // //
_/ _/ / / Department of Sensor Technology
/// // /// Paul-Gordanstr. 5, 91052 Erlangen, Germany
Dipl.-Ing. Martin Meiler
tel.: (+49)-9131-85-23140
fax.: (+49)-9131-85-23133
