I have smome questions about GID customization. I try to create my own
problem type for GID and I want to implement some tcl code for template file
*.bas to generate *.dat file. I have read GID customization manual v11 and I
haven’t found solution for my task. My problem is that:
-I generate mesh on objects like line, surface or volume. I want to get
information about elements (I need elements numbers in list, for example (1
2 3 4) ) associated with this objects.
I know, that I can get information for all elements lying on layer, but I
haven’t seen functions which can return information about elements belonging
to this geometrical objects (lines, surfaces, volumes).
Is it possible ?
For example GiD has tcl function:
GiD_Geometry list element layer:$layerName - this returns elements numbers
for layer
GiD_Geometry list surface layer:$layerName - this returns surfaces numbers
for layer
I need function that returns elements numbers for surface (like above for
layer). For example:
GiD_Geometry list element surface:$surfaceName.
Is there any way to get this information ?
Michał Petaś
programmer,
IPPT PAN Poland
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120912/abe96328/attachment.htm
The elements doesn’t store any information about its geometric source entities, if any, but there is a trick to do what you want,
you can define a condition with a special self-calculated #FUNC#(NumEntity) field
e.g.
QUESTION: Surface_number#FUNC#(NumEntity)
VALUE: 0
When meshing, the condition value will be automatically filled with the number of the geometric source entity,
and you can ask this information with .bas or Tcl commands and reorder this information as you need.
Sent: Wednesday, September 12, 2012 12:22 PM
Subject: [GiDlist] GID development question
I have smome questions about GID customization. I try to create my own problem type for GID and I want to implement some tcl code for template file *.bas to generate *.dat file. I have read GID customization manual v11 and I haven’t found solution for my task. My problem is that:
-I generate mesh on objects like line, surface or volume. I want to get information about elements (I need elements numbers in list, for example (1 2 3 4) ) associated with this objects.
I know, that I can get information for all elements lying on layer, but I haven’t seen functions which can return information about elements belonging to this geometrical objects (lines, surfaces, volumes).
Is it possible ?
GiD_Geometry list element layer:$layerName - this returns elements numbers for layer
GiD_Geometry list surface layer:$layerName - this returns surfaces numbers for layer
I need function that returns elements numbers for surface (like above for layer). For example:
Michał Petaś
programmer,
IPPT PAN Poland
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120912/3782ab61/attachment.htm
