HI all
I’m new to GID and am trying to walk every tutorial. I passed ok the two ones on meshing and pre-processing, and follow the post-processing up to the point of trying to generate iso-surfaces (in both exact and automatic modes), when the program invariably crashes. I’m selecting the option from the “VIew Results” menu, and all the remaining options seem to work ok.
I have installed ver 6.1.2 with the one month optional psw, and Calsef 5.5 also with the temporary allowance.
Below are samples of the error messages obtained.
Any help welcomed. Regards,
GID caused an invalid page fault in
module OPENGL32.DLL at 0177:7abf0e44.
Registers:
EAX=817810d0 CS=0177 EIP=7abf0e44 EFLGS=00010286
EBX=10000000 SS=017f ESP=00b8f990 EBP=00b8fa18
ECX=00717088 DS=017f ESI=00f21030 FS=2cb7
EDX=00000000 ES=017f EDI=00000001 GS=0000
Bytes at CS:EIP:
ff a2 60 03 00 00 8b c0 64 a1 18 00 00 00 8b d0
Stack dump:
00688e97 02bca1ec 10037137 00f21030 00f21030 00688dde 00f21030 00688e60 00000001 0098abdc 0098abdc 0090f745 009749f4 016204c4 01620504 00000001
Registers:
EAX=81789fe4 CS=0177 EIP=7abf0e44 EFLGS=00010286
ECX=00717088 DS=017f ESI=00f21030 FS=646f
Bytes at CS:EIP:
Stack dump:
00688e97 029554a8 10037137 00f21030 00f21030 00688dde 00f21030 00688e60 00000001 0098abdc 0098abdc 0090f745 009749f4 015d04c4 015d0504 00000001
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010531/b6141c43/attachment.htm
hello again;
anybody can explain to me or send me a tutorial to CREATE CONTACT betwen
volumes, i consulted the help, but i did not understand very well.
i suppose, when there is a contact between two bodies, i select surface
in contact (these are in the same plane), and then when i mesh GID
creates elements gaps, but i did not get it.
when i select the surfaces Gid say me “0 new contacts”
a lot of thanks
Pablo
To create a volume contact, the user must select two equal surfaces, physically located at the same position.
(or using Separated volume, can be separated by a displacement/rotation)
Then these two surfaces are meshed with a one-to-one relationship between nodes, and are created degenerated contact elements connecting the nodes. (if it is possible more than one transformation between surfaces, the user is
asked to select pairs of analogous points).
In conclusion, the creation of contact-surfaces or volumes can be considered like a mesh generation option of GiD.
If your program cannot require this one-to-one relation of nodes, you can use a condition to mark the contact nodes or elements.
Sent: Friday, August 03, 2001 3:08 AM
Subject: [ GiDlist ] about contact volumes
hello again;
a lot of thanks
Pablo
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010803/9423fe23/attachment.htm
Name: not available
Type: image/gif
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010803/9423fe23/attachment.gif
