Hi Gidlist
Is it possible to execute a GID batch without opening the main program? maybe by calling some .dll or similar
Thanks very much for your help in advance.
Best Regards
Samir
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20081002/7ffb8649/attachment.htm
It’s possible to run a batch without open any window with the -n option, but graphics features (like save pictures) won’t be available with this option.
gid -b “batchfile” -n
It exists another -n2 option that open the GiD window, but minimized.
Read GiD help about “Invoking GiD” to know the valid command line parameters
Sent: Thursday, October 02, 2008 11:41 AM
Subject: [GiDlist] GID batch
Hi Gidlist
Best Regards
Samir
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20081002/fda29292/attachment.htm
Hello GiD team,
One of our customers encountered an error when he install GiD and
then do first startup,
Error:Couldn’t redirect output to file tmp-gidOutput n temporal
GiD will not start up. His using machine is Windows PC.
How we can solve this trouble?
HEMMI, Shigeru
ITOCHU Techno-Solutions Corporation (CTC)
2-5, Kasumigaseki 3-chome, Chiyoda-ku,
Tokyo 100-6080, Japan
This seems a problem with the name of the temporary path, probably because
your user is working with a Japanese operating system and his username has
Japanese characters.
When using filenames with japanese encoding (Non ASCII characters) then
standard funcions to open files, etc will fail.
It this is the case, he can try some of this options:
a) - In theory this problem was solved in GiD several versions ago, update
to the last available GiD version 9.0.2 (or at least the 8.2.0b, the last
GiD 8.x beta version)
b) - Set the TMP environment variable pointing to some path with ASCII
characters only, e.g. something like C:\Windows\Temp
c) - Use an username with ASCII characters only (this can avoid him problems
with other programs)
From: “HEMMI, Shigeru” shigeru.hemmi at ctc-g.co.jp
Cc: magna at ctc-g.co.jp
Sent: Wednesday, October 08, 2008 1:12 AM
Subject: [GiDlist] Error:Couldn’t redirect output to file tmp-gidOutput n
temporal
Hello GiD team,
HEMMI, Shigeru
GiDlist at gid.cimne.upc.edu
