hello
I want to known where I can find some information about the batch
files!
and How can I get the volume of the block ,which I have select the block, in
bas files.
Thanks!
–http://www.eyou.com
–Îȶ¨¿É¿¿µÄÃâ·Ñµç×ÓÐÅÏä ÓïÒôÓʼþ ÒÆ¶¯ÊéÇ© ÈÕÀú·þÎñ ÍøÂç´æ´¢…ÒÚÓÊδ¾¡
The valid commands for a batch file are the same words showed in the rigth buttons (hidden by default) or written in the command line. The commands history is showed in the undo window or can be saved in a batch file (see preferences).
To read a bath file, use Files-Import-Batch file, or to read interactively use Utilities-Graphical-Read batch window
It is also possible to run GiD without window and execute a bach file. See Help-Invoking GiD.
It is possible to calculate the volume of a hexahedral with the order *operation in the bas file (the volume is the determinant of the matrix with the three edge vectors), similar to the calculation of the normal of a triangle (see the previous mail with subject Re: [GiDlist] Mesh output).
Sent: Monday, July 29, 2002 7:09 AM
Subject: [GiDlist] For helping
hello
files!
bas files.
Thanks!
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020828/310fa90a/attachment.htm
